Badger5AH Fabrications
    Chris0906's Avatar
    YNWA
    Aug 2009
    Runcorn
    Question A4 Bluetooth prep
    Hello All,
    Still quite new to the forum, but really enjoying having a good look around!
    Hopefully picking up a new A4 Exec SE in the next week or so. I have noticed that it comes with bluetooth preperation (low) just wondered what exactly this is? Does anybody know if it is compatible with Nokia E71?
    Chris
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    That's the standard hands free profile bluetooth, it allows you to pair to the car from your phone and transfer contacts/dialled/missed/received calls etc into the MMI. AFAIK the E71 will work fine, if it doesn't transfer contacts then use the Nokia 810 contacts download manager to assist with the transfer.
    pns2007's Avatar
    Nov 2008
    627
    I believe you will have the multifunctional steering wheel in the SE too, which gives you voice activated phone calls. Press the talk button on the steering wheel and you can either speak the number or instruct it to dial a name from your address book (after its been programmed). This is my first bluetooth set up in a car and its brilliant
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
