EM TuningSky Insurance
    pns2007's Avatar
    Nov 2008
    626
    Door warning and puddle light retrofit
    Hi, I would like to retro fit these lights into my doors on my B8 A4. I did it on my 58 plate A3 and was quite simple. Has anyone done it on their B8 A4. Just wondering if the door modules would be the same with the same numbered pins.
    See the following link for the A3:-
    http://audi-sport.net/vb/showthread....ghlight=puddle
    I have looked through elsawin but do not really understand how to translate the wiring diagrams into the actual wiring.
    Thanks, once I've found out I will do an 'how to guide'
    cheers
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    26,774
    I will check the wiring schematics, but can you post up engine & gearbox code as elsawin asks for this & then I can also check etka if door modules are generic
