AH FabricationsSky Insurance
    Jul 2007
    85
    Turbo Part Number
    Hi,
    Can anyone tell me the correct part number of the turbocharger
    that the new A4 2.0 TDI 170cv CR uses ?
    Thanks in advance for your help.
    p.s. I found a GTB1749VM on the Passat 2.0 TDI 170 cv PD, would it be the same ?
    Tetbury Audi Parts Man
    Feb 2008
    Gloucestershire
    260
    03L 145 702E is the A4 turbo, passat is a different turbo. It comes with the exhaust manifold built in to it.
    A3 2.0TDI S-LINE BRILLIANT BLACK (s-line suspension,Audi sound system) coming March (fingers crossed)!
    Jul 2007
    85
    Thanks frenchy2475,
    With the part number you provided I was able to find this information, that I'll leave here.
    http://www.fts.it/catalog/a/38149/bc...039880138.html
    Description Passenger car Manufacturer Part Number 53039700138 Turbo Model BV43 Engine Manufacturer VW Displacement 2.0L KW 125 RPM Max 4400 Fuel Diesel Manufacturer Borg Warner - 3K - Schwitzer
    The manufacturer for me it's a surprise I was expecting Garret
    Jul 2007
    85
    frenchy2475, I have a question fot you.
    Since the turbo installed on the A4 2.0 TDI is different from the one we
    have on the VW passat, which is better ?
    Is the turbo from KKK, or the turbo from garret the better, they may be simillar, but bot equal . . .
    Do you have any idea ?
    Jul 2007
    85
    Found info . . .
    Regarding this "issue", I found two links that might be of interest:
    The New 2.0-l-4V-TDI Engine with Common Rail - Modern Diesel Technology from Volkswagen - ATZ online
    2009 Jetta TDI 2.0 CR Turbo brand ? - Page 2 - TDIClub Forums
    They describe the new CR engines, and the turbo from KKK, I thinks this might be usefull
