    8pj
    Dec 2008
    6
    Using LED only for DRL
    Does anyone in this forum know how to use only the LED's as DRL? I guess I'll have to do some VCDS (Vagcom) coding, but don't know the login code for the module - anyone who knows the trick?
    Regards Per J
    KoFidee's Avatar
    S-LINE
    Mar 2003
    EAST RIDING OF YORKSHIRE
    146
    Hmmm so daytime running lights are not led only then on a B8 as default uk setting?
    8pj
    Dec 2008
    6
    Hmm found out myself - it was pretty straigth forward - didn't even need VCDS. In the MMI the DRL was deactivated! In VCDS it didn't make any differece it at all if I toggled bit 4 in the entral electronics module or not.
    PS The car is situated in Denmark
    Quote Originally Posted by 8pj View Post
    Regards Per J
