JMB RetrofitsVolks Autos
Results 1 to 8 of 8
    Dec 2013
    126
    Will my S-Tronic G-Box handle it?
    Thinking of a Re-map for my V6TDI to 290bhp.
    This will also take the TQ from 500NM to @640NM, the 7-speed S-Tronic is noted as being able to 600NM.
    So is a re-map such a good idea? will it destroy my box?
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    645
    Personally, I wouldn't because of the cost of the various components of the DSG box. Why not ask the remap company to take the torque to 570nm or so?
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    Audi Dynamik's Avatar
    Sep 2011
    2,121
    Where are you thinking of getting it done ? As said above ask them to take the torque lower so the gearbox isnt being strained.
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    Bustamoves's Avatar
    Flat Foot Shifting
    Apr 2014
    West yorks
    139
    550nm is recommended but I recon 600nm would be ok as long as you don't launch it frequently
    The new Audi S tronic 7-speed gearbox
    Dec 2013
    126
    Starting to think it's not worth the hassle for 50NM's?
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    It depends, you can extend the powerband, so it makes the increased torque for much longer, making it feel a lot free-er revving.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Dec 2013
    126
    I got this wrong, it's the Transverse one that handles 600NM, the one I have is 550NM as noted in the article above, so thanks for the info guy's. I think the wise thing to do is not take risks with such a complicated and expensive gearbox, shame though as nearly 300bhp would have been fun.
    markm,'s Avatar
    Feb 2014
    Portsmouth
    49
    Quote Originally Posted by Audi.Quattro View Post
    What about this info seems they changed some figures from 2009 :-) gives you the magic 600nm
    Audi longitudinal DSG[edit]
    In late 2008, an all-new seven-speed longitudinal[7][13] S tronic[13] version of the DSG transaxle went into series production (Volkswagen Group internal code: DL501, parts code prefix: 0B5).[8] Initially, from early 2009, it is only used in certain Audi cars, and only with longitudinally mounted engines. Like the original six-speed DSG, it features a concentric dual wet multi-plate clutch.[13] However, this particular variant uses notably more plates — the larger outer clutch (for the odd-numbered gears) uses 10 plates, whereas the smaller inner clutch (driving even-numbered gears and reverse) uses 12 plates.[13] Another notable change over the original transverse DSGs is the lubrication system[14][15] — Audi now utilise two totally separate oil circuits.[13] One oil circuit, consisting of 7.5 litres (1.65 imp gal; 1.98 US gal), lubricates the hydraulic clutches and mechatronics with fully synthetic specialist automatic transmission fluid (ATF),[13] whilst the other oil circuit lubricates the gear trains and front and centre differentials with 4.3 litres (0.95 imp gal; 1.14 US gal) of conventional hypoid gear oil.[13] This dual circuit lubrication is aimed at increasing overall reliability, due to eliminating cross-contamination of debris and wear particles.[13] It has a torque handling limit of up to 600 N·m (440 lb·ft),[7] and engine power outputs of up to 330 kW (450 PS; 440 bhp).[7] It has a total mass, including all lubricants and the dual-mass flywheel of 141.5 kg (312 lb).[7]
  1. S-tronic gearbox to handle more power
    By h5djr in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 4th January 2013, 18:15
  2. S tronic gear boxes..
    By martininwillerby in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 22nd October 2009, 09:27
  3. Glove box handle ?
    By peter02 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st October 2009, 21:08
  4. S-tronic gearbox to handle more power
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st March 2008, 08:39
  5. S-tronic gearbox to handle more power
    By h5djr in forum A5/S5/RS5 Forum
    Last Post: 12th March 2008, 19:33
