Badger5Sky Insurance
    Nov 2013
    72
    Wind noise Avant drivers door 2010.
    Anyone had issues with wind noise on drivers door A4?
    Passenger door is fine so I just wondered if the more constant use of the drivers door has caused wear and hence the extra noise?
    Door seals are pretty clean so just wondered what I could do to solve the issue?
    May 2012
    Bucks
    67
    I recently have noticed this getting worse on my car not sure what the answer is? Anyone ?
    61 Plate Audi A4 Saloon Black Edition 2.0 TDI 170 in Lava Grey
    Feb 2008
    Rubber on door seals seems to dry and then not mate as well with door shut. At least on mine and others I've read.
    Silicone lube applied to door rubbers seemed to solve for me.
  1. Wind noise Driver's Door?
    By Spacer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2013, 00:45
  2. B6 a4 avant drivers door latch closes itself!
    By glenandem in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2013, 16:17
  3. 2001 avant drivers door lock issue
    By mrnice in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st May 2013, 11:51
  4. wind coming through drivers door
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2010, 14:42
  5. 96 avant dvr door lock -driver plate ?
    By Crombie in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th April 2009, 19:37
