Results 1 to 14 of 14
Like Tree3Likes
  • 1 Post By Jamie-S
  • 1 Post By bez101
  • 1 Post By bez101
Thread: Fitting b8 sill trims / blades ??
    Jan 2014
    26
    Hi all.
    I was hoping to find and fit some 2nd hand s-line sill blades to my SE saloon. Would I be right to assume that they clip onto the car by way of a fitting kit available from audi ?
    Thanks people
    Nov 2010
    346
    Finally installed the satin silver S line side blades (AKA: stone guards) More Pics!!
     The stone deflector stripis secured additionally to the side member with adhesive tape.
     Is destroyed when removed.
     When removing the stone deflector strip, the clips are also damaged irreparably and must be renewed.
    Removing:
    – Heat bonding areas with hotair blower and gradually pull stone deflector strip off side member to the side.
    Note: When the stone deflector strip is detached, the clips are pulled off the retaining pin and must be renewed.
    Installing:
    – Kink protective film removal aids upwards so they are reachable when stone deflector strip makes contact with side member.
    – Push stone deflector strip onto clips as far as stop, working from rear to front.
    – Follow the order of removal for removal aids.
    – Gradually press stone deflector strip firmly onto side member.
    Clips:
     9x
     Installation direction for clip is embossed.
     Slide clips onto studs in correct direction and engage.
     Align clips lengthwise to side member.
    Order of removal for removal aids
    – Peel off removal aids in the sequence : 1, 2 ,3 and 4.
    Jan 2014
    26
    Thanks for the detailed answer. Was hoping it bonded to the car. Not keen on drilling holes in the car so might have to find someone with more cojones than me !
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    A few people have used double sided 3m tape with no problem, if your worried additionally you could put a blob of sikaflex where each clip would go.
    I bought my blades ages ago just can't be bothered to fit them lol
    cyberstretch likes this.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    use some double sided tape
    to hold in place till the bond sets
    bez101's Avatar
    Jul 2008
    8,491
    Quote Originally Posted by Jamie-S View Post
    hmm are you selling them ?
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    I did consider it, but they have been freshly painted in phantom black
    bez101's Avatar
    Jul 2008
    8,491
    thats the colour of mine
    i missed out on a set in black on the bay last night aswell
    Jan 2014
    26
    You weren't the only one !
    bez101's Avatar
    Jul 2008
    8,491
    the seller was bidding up
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    How did the set go for last night?
    bez101's Avatar
    Jul 2008
    8,491
    i think around 80
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    That's what i payed for mine, then spaying cost
    bez101's Avatar
    Jul 2008
    8,491
    well if they do come up for sale let me know
    Jamie-S likes this.
