Sky InsuranceJMB Retrofits
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By vw754
Thread: dpf-----------regen
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,974
    dpf-----------regen
    Hi, ive just checked with vcds.......soot mass calculated 10.14g soot mass measured 10.49g
    does it need a regen?
    If not when will the car regen itself?
    I tried do a regen while standing,but vcds says 'aborted for safety reasons'
    im not 100% on this but i think rosstech site shows regen of pd engines,not cr tdi like i have(could be wrong)
    Full leather/19"wheels/cruise/
    dieseldoos's Avatar
    Apr 2013
    Hampshire
    137
    2009 ​Audi A4 2.0TDI S-Line (143)
    Fully registered VCDS in Portsmouth & surrounding areas , and fault scanning of other makes.
    Anthony566's Avatar
    Nov 2013
    North East
    614
    2013 A4 2.0 TDi 177 quattro Black Edition - Glacier White
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    had a try with this,the meas blocks 08 is always not available....greyed out,and it says ,aborted due to safety reasons,when trying to regen
    Quote Originally Posted by dieseldoos View Post
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    maybe........its not full enough?...........according to this i cant ,its got me more full than 10.14g/10.49g ?
    .6l/2.0l R4 CR-TDI
    With the newer CR-TDI engines there are 2 different types of regenerations available depending on the actual soot mass/load. If either the calculated or measured soot mass is above 30g but below 40g you can initiate a regeneration while standing (Idle will be raised etc.), a forced regeneration while driving is also possible. Once the values are above 40g (but below the max 45g) the regeneration while standing is no longer available and the regeneration while driving is the only way
    Nov 2010
    350
    Just go for a 20 mile motorway blast in 3rd........
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    dpf's dont regen by blasting/thrashing in any gear.
    Quote Originally Posted by Zafi View Post
    Audi Toby! likes this.
    Jan 2014
    26
    No it doesn't, but it does generate the temperatures required to burn the soot off and clean the filters.
    Using Tapatalk
    Nov 2013
    Heath Hayes
    951
    DPF's will do passive regeneration if driven on a motorway at a reasonable speed. The temperature should reach a suitable level to start burning off the built up carbon. This is why cars driven on motorways regularly are less susceptible to having a blocked DPF.
    diesel particulate filter (dpf) | AA
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Nov 2010
    350
    I have done about 300,000 miles in DPF cars since 2004 and never had and problem whatsoever. Free flowing cross country driving, hardly any queues through towns, motorway maybe twice a month.
    The only time I did have a problem is when I fitted a tuning box and within 400 miles the DPF light came on, so I sent the box back and took the car for a high revs drive and it cured itself.
    Audi Toby!'s Avatar
    B8 A4 S-Line
    Jun 2013
    Norwich, Norfolk, UK
    227
    Quote Originally Posted by vw754 View Post
    .6l/2.0l R4 CR-TDI
    10g to little to do a regen. It will only let you do a manual regen when it is nearly full (30g and above) if I drive on my commute (20mins 60mph road) it will regen between 15-20g on its own every week or so.
    2009 (B8/8K) A4 S-Line - 2.0TDI (CAGA) 143PS.
    Monza Silver, Special Line, Full Milano Leather, Sport Suspension (1BE), AMI + Bluetooth/Voice Prep, Heated Seats, Bang & Olufsen (Upgraded/Improved), Audi Titanium Grey Wheel Refurb, Team HEKO Wind Deflectors, VCDS'ed, Ambiance Lighting Retrofit, Cruise Control Retrofit, (ADS) Audi Drive Select Retrofit.
    Find me on the 'official' VCDS map >>
    http://goo.gl/5NrQwS<<
  1. DPF Regen so soon?
    By snakehips in forum New A3/S3 (8V Chassis)
    Last Post: 20th December 2013, 15:00
  2. Did I just experience my first DPF Regen?
    By The Governor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2012, 10:40
  3. Audi DPF document
    By Markm49 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2007, 17:48
  4. Remap of 170TDi DPF Engine
    By JED in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2007, 20:25
  5. Audi A3/Sportback 2.0 TDi (DPF)
    By dorgan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2005, 22:01
