EM TuningVolks Autos
Results 1 to 24 of 24
Like Tree3Likes
  • 2 Post By Liquidfusion
  • 1 Post By SI-W85
Thread: Intermittent clutch slip
    Nov 2013
    County Durham
    42
    Hi All,
    2011 A4 Avant manual 6 speed 2.0 TDI 140, noticed when driving yesterday when accelerating in 6th from around 1600 rpm in top gear the clutch seems to slip for a couple of seconds, it doesn't happen all the time infact yesterday was the first time I ve noticed it tho I don't drive it as much as the wife who doesn't think it's happened when she's being driving
    Could this be a sticking pressure plate or perhaps an oil seal issue, no doubt it'll need to develop before a diagnosis can be made
    would you contact Audi now incase this is a warranty job
    thanks in advance Andrew
    Nov 2013
    Heath Hayes
    951
    How many miles has the car done ? .Sounds like the clutch to me, If it's a clutch or an oil seal the gearbox will need to come off and I would of thought a clutch wouldn't be covered under warranty especially if the car has some miles on it.
    Karl.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Nov 2013
    County Durham
    42
    Hi Karl, just turned 30k
    Seems fine 99% of the time under load etc never missed a beat, doesn't skip under harsh acceleration through the gears or 9 times outa 10 if you let it pull from low down in sixth.
    I thought I was imagining it at first, but twice yesterday it happened pulling from low revs on the motorway
    Nov 2013
    County Durham
    42
    By the way Karl, love the thread on your 3.0 tdi mods, looks a mint car
    Nov 2013
    Heath Hayes
    951
    Thanks for that it's getting there.
    At only 30K there shouldn't obviously be an issue with the clutch. Doesn't have a tow bar does it ? .
    Just trying to think what the dealer will say if you turn up with a 30K car and say the clutch is slipping.
    Depending on what they find if they do take it apart if it's not an obvious manufacturing fault with the clutch or a parts failure then you may have to pay for some of the work.
    Karl.
    Audi Dynamik's Avatar
    Sep 2011
    2,121
    Clutch is definitely not covered under warranty.
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    Nov 2013
    County Durham
    42
    Hi guys,
    I maybe didn't make such a good job of explaining myself, I totally understand the clutch not being a warranty item as it's wear and tear, my question is Is the intermittent slip signs of maybe a sticky pressure plate or possibly an oil seal issue? 30k is nowhere near enough miles in a bog standard non modded car to wear a clutch out surely
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    Visit SI-W85's Instagram Channel
    I have the exact same issue as you sometimes it slips and then the next day I can't make it slip at all even by dipping the clutch in a high gear :/ so I have booked in for a new clutch and flywheel so see if that sorts it lol mine has just gone 50k
    Custom stainless straight through quad pipe, S5 brake callipers, Black diamond grooved discs, red stuff pads, S4 diffuser, EGR delete, stage 1 remap, 19" staggered X5 wheels, G23 custom adaptors, stretched tyres, window tints, coilovers, vag com mods, K&N, led interior lights, led number plate bulbs, pressed plates, black edition grill. Plenty more to be done.
    Nov 2013
    County Durham
    42
    Quick update guys,
    I'm stuck between a rock and a hard place,at least that's how it feels, should Audi remove the box and find a fault to cause the intermittent slipping clutch then they'll repair under warranty, if it's wear and tear its £1497 and a few pence, so do you go with your gut instict and give Audi the car, take the risk of it coming back at £1497 odd or go to and independent for a third of that price only to discover you could of had it done for free under warranty?
    Should anyone have a crystal ball I can borrow pls feel free to holla
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    Can you not take it to another garage get the clutch done and them take to Audi for inspection???
    Nov 2013
    County Durham
    42
    Hi SI-W85
    I wondered that but I think Audi would knock that back as there's no way you could prove its the clutch plate etc from your car, strangely VW main dealer only want £874 to replace the clutch, so unless Audi are also changing the flywheel why over £600 difference for the same clutch
    I'm sure the answer is at the bottom of this whiskey bottle
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    It will be for the flywheel too I would say, yes that may be a problem with proving it is from your car, I am going through a similar thing to you mine is booked in at another garage tommorow for clutch & flywheel £800 all in, I have been told I am allowed to take my car to another garage for the work doing as mine is a juddering flywheel & clutch slip. We will see what comes of it when I ring the Dealer to say its been done but I suspect nothing
    Nov 2013
    County Durham
    42
    Audi are ringing back tomorrow to give me there best guess, after that it'll be decision time, I notice if your car is 3 years or over and 2.0 ltr or under Audi will fit a clutch for £749, mine will be 3 years old at the end of June, I wonder if she'll go till then lol
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    If that's just a clutch then that is expensive, like I say mines clutch and flywheel and bearing for £800 all in. Mine started slipping 2 week ago and it isn't a daily driver but it is now on its last legs slipping really bad.
    Nov 2013
    County Durham
    42
    Noticed this on Sunday for the 1st time,only happens once in a blue moon but the wife drives it daily so it needs sorted, it doesn't judder pulling away, only slips when you put your foot down in top gear. From 1600 revs,climbs to 2000 n slips for a couple of seconds then bites and returns to normal, seems to happen on,y when it's up to temp on a decent run
    Sep 2011
    2,121
    I had to have my Clutch & Flywheel replaced as it just out of the blue went and started burning without no sign or slipping beforehand.
    I just went to give it a little blast and it just revved and didn't go anyway and the clutch were burning. 27000 miles not even 3 years old but i do suspect it is the remap hence i have put it back to stock.
    Audi wanted £2000 for it and they would of put £1000 towards it if it weren't remapped so i took it elsewhere and had it done for £800 instead and get 2 years warranty with it.
    Liquidfusion's Avatar
    Sep 2011
    London
    361
    Quote Originally Posted by Audi Dynamik View Post
    Too much powaaaaaaaa
    Audi Dynamik and SI-W85 like this.
    2013 Audi A4 1.8 TFSI 170 S line - Daytona Grey. 19" Black Edition Alloys. MMI 3G Navigation Plus, Bluetooth Phone and Voice Prep,
    Heated Seats, Cruise Control, Eibach Sportline Suspension, Tinted Windows Factory Shade,
    Ice White Fog Lights, Interior LEDs, Mobius Dash Cam, Red Calipers with S Line Decals
    S Line Grill Badge. Remap Stage 1 (Pending)
    Sep 2011
    2,121
    I know i realized, its back to stock now anyway. I told Revo about it and they were adamant that it were not the Revo software.
    Nov 2013
    County Durham
    42
    Those things you come to expect when you've remapped, this is totally stock,tho I'm now wondering if it's worth upgrading the clutch while it's out, if I'm paying I may as well put in what I want.
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    Exactly pal that's what I'm doing anyway.
    Drew Baby likes this.
    Dec 2011
    Somerset
    502
    Is there uprated clutches available for the B8 ?
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    I know there is for my diesel because I've got one lol
    Sep 2011
    2,121
    Quote Originally Posted by Drew Baby View Post
    Thing is, when i asked Revo before i got it done would i have any problems with the clutch they said there will be no problems whatsoever!
    Nov 2013
    County Durham
    42
    Spoken to an Audi specialist this morning, they have just done another A4 with the same fault, apparently there's an upgrade for the clutch master cylinder,tho Audi Newcastle say not, Audi Newcastle are however going to investigate the problem and tell me what is, FOC,wether its covered under warranty and if not, if not how much to rectify. So until I've an answer from Audi I'll just hold my breath and pray my gut instinct is right and there's an underlying problem
    Thanks for all your help
  1. Intermittent clutch slip - could not demonstrate to dealer
    By heyes_s in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2011, 15:35
  2. Clutch slip! & another problem
    By IanMcA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2005, 23:33
  3. is my clutch slipping?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2004, 19:29
  4. chipped A3 tdiq clutch slipping....anyone else??
    By A3Lee in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 23:38
  5. clutch (slipping?)
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2003, 12:29
