JMB RetrofitsSky Insurance
Results 1 to 15 of 15
    Jul 2013
    140
    Juddering when setting off, hard to get into 1st
    Hi all
    i had the DMF and new clutch done about 3,000 miles ago but I've noticed recently it's hard to get into 1st gear and juddered when setting off, in cold and when the car warms up. If I over rev when setting off there is no juddering.
    Is this symptoms of the release bearing failing?
    Or could it need a software update? How can I check if it has ever had the update?
    I'm unaware of when the last gearbox oil change was done, if this could cause these issues.
    Any other ideas?
    Just a bit annoyed that after new DMF and clutch these issues are still there
    john
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Which engine do you have?
    Jul 2013
    140
    Quote Originally Posted by Jamie-S View Post
    Sorry mate should of said, it a 2008 2.0 Tdi 143, manual gear box
    Jul 2013
    140
    Any help on how to check if it's had the software update for the clutch sensor first
    Then I can start looking at other options.
    Jul 2013
    140
    Any help, anyone?
    May 2012
    29
    I have same issues, audi will not admit their flywheels are crap.
    For the gear changing try a fully synthetic oil. That should help.
    Jul 2013
    140
    Quote Originally Posted by trance View Post
    It's due a full service next month so will do that then
    Have you had the software update and did it help with your issue?
    Jul 2010
    Plymouth
    37
    I have this issue on my 2008 B7 2.0tdi... its just been in the garage and their flippant diagnostic was that it needs a new clutch, but i'm not 100% that will cure the fault, and bet its not cheap on these!! Looking for answers too, sorry I dont have any, just feeling your angst!
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    Visit SI-W85's Instagram Channel
    Quote Originally Posted by J1 MBO View Post
    If its juddering its most likely the flywheel but you may as well do the clutch while your in there.
    Custom stainless straight through quad pipe, S5 brake callipers, Black diamond grooved discs, red stuff pads, S4 diffuser, EGR delete, stage 1 remap, 19" staggered X5 wheels, G23 custom adaptors, stretched tyres, window tints, coilovers, vag com mods, K&N, led interior lights, led number plate bulbs, pressed plates, black edition grill. Plenty more to be done.
    Jul 2010
    Plymouth
    37
    Quote Originally Posted by SI-W85 View Post
    Faith restored in my regular German Marque Specialist garage, explained the need for replacement clutch, but like you say it's the dual mass flywheel that's at fault, it just makes sense to do the clutch while it's stripped down, like you say! Thanks! May put it off as advised by the garage after the quote came in at £950!!
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    Go on darkside developments to buy your flywheel/clutch kit £400ish mine is the same but only slight judder I'm just putting it off really until it gets a bit worse but I've had 2 quotes of £800 all in for replacement flywheel & clutch.
    Jul 2010
    Plymouth
    37
    Ha ha, yea, I'm just going to put it off for now too!!
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    I now have clutch slip since my remap think its going to have to get done sooner rather than later now...
    Jul 2010
    Plymouth
    37
    Oh no - that sucks! Would the remap have actually caused clutch slip?!?!
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    It definitely wouldn't have helped it with the extra torque the clutch will not last as long however my car has just reached 50k and this is the 3rd clutch to go in it apparently when they got in there they realised it wasn't Audi original so that's not very good of a car of that mileage.
  1. Juddering when pulling off
    By Timmy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th May 2011, 20:26
  2. crunching noise when setting off.
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2011, 22:23
  3. Replies: 2
    Last Post: 25th February 2011, 21:49
  4. Squealing noise from Clutch when setting off in 1st
    By evilbane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd January 2011, 17:23
  5. Sideways Vibrations/Juddering when foot off the gas? Help/Advice needed
    By Sarah's A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2011, 00:52
