EM TuningAH Fabrications
Results 1 to 20 of 20
Like Tree3Likes
  • 2 Post By Keef
  • 1 Post By Anthony566
Thread: Possible to retrofit Mobile Phone Prep - High?
    allanmb's Avatar
    Feb 2014
    I am wondering if it is possible to retrofit the 'Mobile Phone Prep - High' option on a new facelift A4? I would like to have access to the online services like advanced traffic and google maps. Is this possible? And if so, how much would I be looking at? I already have MMI 3G if that makes any difference.
    Allan
    Audi A4 2.0TDI Quattro 177PS Black Edition (B8) in Brilliant Black, B&O sound system, MMI plus satnav, Parking System plus
    Keef's Avatar
    Jun 2006
    Warwickshire
    508
    Quote Originally Posted by allanmb View Post
    Allan
    Yes, defo possible, has been done a few times - but I understand, depending on your original set-up it could be as much as £2-3k!
    'NHN' on here might be able to help or if not then a guy called 'II Ben' over on 'A5OC' can do it for you.
    Keef
    NHN and allanmb like this.
    S4 Avant quattro Black Edition
    27,099
    On your year of car & sig spec, haven't you got 3G+ installed?
    allanmb's Avatar
    Feb 2014
    No, the standard is Mobile Prep - Low. I don't have the SIM slot (which I don't need), nor do I have the ability to connect to a phone to use the remote sim access which is the part I want.
    Anthony566's Avatar
    Nov 2013
    North East
    614
    I'm sure mine is 3G not 3G+ it is a bit odd that you cant use the bluetooth connection for the data connection that the 3G+ needs for the extra google map detail ......
    Unless I am wrong about this ??
    2013 A4 2.0 TDi 177 quattro Black Edition - Glacier White
    allanmb's Avatar
    Feb 2014
    That's exactly what I thought. But it would seem you need the option before you can connect data :-(
    Anthony566's Avatar
    Nov 2013
    North East
    614
    it is a bit crap really but I still like the car .....
    my build list says this
    -[7T6] MMI navigation plus
    Follow this link ..
    Audi A4 Satellite Navigation & HDD Navigation – A4 Saloon - Audi UK
    Half way down on the right it does say you need mobile phone prep High ....
    So I would like to know also if this can be added and then coded up ??
    Anthony566's Avatar
    Nov 2013
    North East
    614
    Does anyone know if this is possible ?? Or has anyone already had this done ??
    allanmb's Avatar
    Feb 2014
    I take it nobody know whether or not this is possible? If so, please add some info to the thread...
    Anthony566's Avatar
    Nov 2013
    North East
    614
    Has no one done this retro install ??
    allanmb's Avatar
    Feb 2014
    I am starting to lose hope that this isn't possible. I guess it might be worth asking Audi but I imagine they will charge big bucks...
    27,099
    It is possible, but its very expensive.
    allanmb's Avatar
    Feb 2014
    Are we talking over a grand?
    Anthony566's Avatar
    Nov 2013
    North East
    614
    Have you seen this topic ??
    let the MMI 3g+ conversion begin =)
    allanmb's Avatar
    Feb 2014
    Quote Originally Posted by Anthony566 View Post
    Thanks! This appears to be mostly concerning upgrading the unit from MMI-3G to a 3G+ rather than just the mobile prep high, but there are some useful pieces of information in there. It will take a while to trawl through it all.
    I did, however, notice this little nugget:
    "Note that the tel_settings under diagnose/settings lets you turn on and off HFC/NAD/etc. This means you can also enable Telephone Preparation High, without a cradle or SIM slot. Unfortunately, I've not been able to test it because iPhones don't support rSAP! "
    That sounds very promising! It basically just requires accessing the hidden menu in the MMI. I'm not sure if my Samsung Galaxy Note 2 supports rSAP but it's worth a shot!
    Anthony566's Avatar
    Nov 2013
    North East
    614
    You will need this for rSAP http://www.android-rsap.com/installation.html
    You will also need to root the device ... google this for a how to...
    I am not sure if this will do what you need or not as far as I can see to have the mobile phone prep hi you need the CD head unit with the sim card slot in it .... but I am still trying to confirm this ... also to use the in car areal you need to install the cable as well ....
    allanmb likes this.
    allanmb's Avatar
    Feb 2014
    You will need this for rSAP How To Install rSAP
    Not sure if I will need the in-car aerial. I will try and get my phone prepared for trying this out at the weekend and I will report back
    Anthony566's Avatar
    Nov 2013
    North East
    614
    I also did find information that seemed to confirm that if your car is MMI 3G you only need to swap the head unit...
    "For 3G MMI it's a direct swap and the only wiring needed is an antenna wire for GSM for google. The NA cars should have that connection waiting on the antenna though"
    Have a look at this one as there is also a lot of info in it
    New Google MMI installed in 3G car 100% working - A5_OC
    Mar 2014
    Bucks
    130
    I noticed that too. I was thrashing around in my 3G MMI hidden menu the other day and saw those settings. Also network settings like DHCP / Static IP etc. You'd think that if phone prep low was written in stone by being hardware dependent the software wouldn't be installed. I'm hoping it's a simple case of tweaking the settings. I left it well alone but…..hmmmm
    Mar 2014
    Bucks
    130
    Ok,just had a little play. In the Hidden Menu; changing Tel /diagnose/settings/no WIFI/NAD/BT/HFC AND AMI settings/no Aux/ AMI BT/AMI made no difference whatsoever with my Blackberry. Checked Audi BT device properties [refresh service list] still had only Hands Free unit and Headset Audio Gateway. No addition settings or features on MMI.
    Maybe a bit of 5F coding needed?
  1. Armrest Phone prep - retrofit
    By manor13 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2014, 21:19
  2. AUDI Bluetooth High mobile phone interfaces units for A2 A3 A4 TT
    By corino in forum For Sale/Wanted - Audi Parts
    Last Post: 16th October 2013, 07:16
  3. mobile prep high - iphone 4s
    By coupsta in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 14th May 2013, 09:08
  4. Retrofit Armrest Phone Prep
    By S4_marv in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th October 2009, 16:04
  5. Fitting a mobile phone kit HELP
    By imported_christhick in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2004, 11:53
