Badger5Sky Insurance
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Audi.Quattro
Thread: Heated Mirrors
    Macdoon's Avatar
    Essex
    1,569
    Heated Mirrors
    Hi all, I have noticed that when switching on heated screen the heated wing mirrors do not heat up. read the manual and it says they are temperature controlled - is it possible to change this via vcds to come on with the rear screen?
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    27,096
    Try putting the mirror switch to the middle position.
    Macdoon's Avatar
    Essex
    1,569
    Cheers Nigel, is that put the switch in the middle then press rear heated screen switch?
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Just leaving it in the middle position will mean they heat up when required automatically.
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Jan 2014
    does leaving it in the middle not leave the heated mirrors on all the time?
    Dec 2013
    126
    Yes, but they will only work if its cold enough
    Daggerit likes this.
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    I just replaced one of my mirror glasses, the heater had failed. Mine work regardless of the switch position.
    You can easily pop the mirror out by turning the mirror in as far as it goes, put a screwdriver in from the lower outer edge and feel for the (roughly 2" diameter) clip that holds the mirror glass, carefully prize it out. It's very unlikely to break the glass. Test for 12v feed when ignition is on. CID you have 12v the heater element is knackered. Scrappy will probably want £15 for a complete mirror, I just left the rest of the mirror and took the glass, happy to pay £15 just for the glass
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    £15 for a b8 mirror ?
    get me 10
    Macdoon's Avatar
    Essex
    1,569
    Quote Originally Posted by Daggerit View Post
    Cheers pal, this is why I want to know if the heated mirrors can be switched on when needed other than when it reaches a certain temp, when the mirrors are misted up after a wet night I would usually switch on the mirrors that would clear it, but if they are set to auto heat then it won't
    May 2013
    Southern Scotland
    250
    I thought that the mirror heaters in Audis had thermostat "protection" and not a thermostat to allow them to come on, ie the thermostat avoids burning out the elements. When I moved from VX Cav GSI 4X4 to VW Passat B5 2.8 4Motion, I stupidly assumed that it was clever/smart to leave the mirror switch on the heater position, thus avoiding accidentally adjusting the mirrors when bumping into the switch, and making the assumption that by doing that, the mirror heaters would always come on with the heated rear window (like the GSI did). About 12 months down the line, I read on the USA Passat forum that people were trashing their mirror heaters by doing that - checked mine - both heaters burned out, so bought new mirrors and only used the heaters when needed.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Quote Originally Posted by Macdoon View Post
    I don't know if yours work a bit different than mine then? I just leave mine in the middle position all the time unless I actually need to adjust them.
    An example is if there's some frost I'll start the car and go round scraping the windows, but the time I get back in the car the mirrors are clear. That's just leaving it in the auto position.
    Would yours not do this?
  1. Heated Mirrors standard?
    By imported_ashs3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2004, 18:54
  2. Heated Mirrors stopped working - AGAIN!
    By Naresh in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2004, 22:08
  3. Heated Mirrors (Retro fitting)
    By nhenty in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th February 2004, 22:08
  4. Heated Mirror Problem??
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2003, 10:24
  5. heated mirrors not working.
    By moschino in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2003, 17:14
