Hi all, I have noticed that when switching on heated screen the heated wing mirrors do not heat up. read the manual and it says they are temperature controlled - is it possible to change this via vcds to come on with the rear screen?
Try putting the mirror switch to the middle position.
Just leaving it in the middle position will mean they heat up when required automatically.
Cheers pal, this is why I want to know if the heated mirrors can be switched on when needed other than when it reaches a certain temp, when the mirrors are misted up after a wet night I would usually switch on the mirrors that would clear it, but if they are set to auto heat then it won't
