Badger5Volks Autos
    rabhrab's Avatar
    Oct 2004
    Central Scotland
    68
    Avant rear wiper arm removal (or not, as in my case!).
    Hi. I bought a new rear wiper arm and blade and thought.... five minute job! I've removed the cover and removed the locking nut which was tight and a bit rusty, but can I get the arm off? No! It is a tapered fit onto the drive and is seized solid. I've left it soaking in a releasing agent bath and then tried with a puller (battery terminal type) but with no joy. As you can imagine I don't want to employ too much of a 'strong arm' tactic, so I'm looking for any suggestions? Leave it soaking over night? Cut it off... although this would be drastic! Thoughts please!
    2009 S4 Avant, manual trans.
    kite's Avatar
    Oct 2007
    East Berks
    675
    Take it to a local windscreen place and ask them to remove.
    A4 (b6) 2.5 TDi QS Saloon.
    Dec 2013
    126
    they usually on a tapered spline, get a cheap tool from FleaBay is another option. They look a bit like a gear/bearing puller
    rabhrab's Avatar
    Oct 2004
    Central Scotland
    68
    Quote Originally Posted by Audi.Quattro View Post
    Patience is a virtue! After posting the initial time, watched a bit of 'telly and had a coffee, went back to the job and hey presto! The release oil must have done the job and with the aid of the battery terminal puller, the arm came off the splined shaft! New arm and wiper fitted......... satisfaction achieved! Now, what's the next fix I can get myself into............?
    Oh, thanks for the replys!
  1. Avant rear wiper removal
    By A4 TC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st May 2010, 21:36
  2. Removing Rear Wiper Arm & Workshop Manual
    By circleswim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2010, 01:21
  3. Rear wiper arm replacement
    By Ben_yo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2006, 20:07
  4. Wiper Arm Removal
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th December 2006, 02:14
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
