Volks AutosBadger5
Like Tree1Likes
  • 1 Post By viceroy
Thread: P1719 error - My experience
    viceroy's Avatar
    Aug 2011
    Johannesburg
    206
    Hey guys,
    I just wanted to share my experience with this error.
    There is not much on the web related to Audi and this error, but one thread was right here on this forum.
    LINK
    Now my experience was different and my code was slightly different too.
    The error I got was 3 days after remapping the car
    Sunday,09,February,2014,12:52:10:61998
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    VIN: WAUZZZ8K49A140323
    License Plate: CH18KNGP
    Mileage: 90907 Repair Order:
    Address 02: Auto Trans Labels: 0B6-927-156.clb
    Control Module Part Number: 8K0 927 158 A HW: 0B6 927 156
    Component and/or Version: 0B6 30 TDIRdW H04 0050
    Software Coding: 001001
    Work Shop Code: WSC 06325 000 00000
    ASAM Dataset: EV_TCMAL651 A01004 (AU48)
    VCID: 3461A4979FC941BE40B-8061
    1 Fault Found:
    4765 - Functionality limited due to Engine Control Module
    P1719 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 7
    Mileage: 90514 km
    Date: 2014.02.08
    Time: 07:59:50
    No MIL came on, but I did notice a lack of power and my fuel consumption went up.
    I only scanned the car a few days later, and then found the thread linked about, so cleared the code and drove for a few more days, and then rescanned.
    The error was back, and other than a slight loss of power, and the worsened economy, there were no other symptoms or error codes in the engine module.
    I asked my tuner what he thought, and he suggested we reflash the car back to stock, except leave the DPF coding since I'd already removed mine.
    Anyway before I'd gone to reflash to stock, I was sat in the car just going through long codings and to clear the error again, and I saw that "DPF installed" was ticked.
    I unticked it, and applied the new coding.
    Since then, the car has been back to normal, and economy is better again.
    Hopefully no-one else suffers this, and I've told my tuner that if he does a B8 again, he must change the log coding as well as code out the DPF regen.
    NHN likes this.
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    27,096
    Well done for reporting back for others.
    viceroy's Avatar
    Aug 2011
    Johannesburg
    206
    Well the error came back, but performance and consumption are unchanged, so I'm going to guess at more than one issue.
    Code is almost identical except for the underlined number
    It was:
    P1719 00 [032] - -
    It's now:
    P1719 00 [038] - -
    Does anyone know what that number indicates?
    As for the error, I just happened to have the GoPro filming my gauges on the same drive when the error happened.
    Full throttle
    3rd gear.
    "Tiptronic" mode (+-)
    Just before or as the car changed up to 4th (I didn't change manually)
    This morning, there was no error as I was in 'S' or 'D' the whole time.
    Tried a 2nd gear blast changing up to 3rd in 'S' which didn't trigger the code, so to night I'll try a 3rd gear blast in 'S' to see if that triggers the code.
  1. Anyone have any experience with Abt chips?
    By plampine in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 22nd July 2003, 22:36
  2. Audi Experience Drive Day
    By IML337 in forum Other Brands & Models
    Last Post: 18th June 2003, 12:38
  3. CD-Error 2 problem???
    By Jack829 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th April 2003, 21:30
  4. Errors!
    By A4Steve in forum General Chat
    Last Post: 7th February 2003, 10:17
  5. any one have any experience EXPORTING a car?
    By sfource in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 03:18
