Page 1 of 2 12 LastLast
Results 1 to 40 of 56
Like Tree56Likes
Thread: Audi A4 B8 S line Bumper Removal / RS4 Grille Fitment Step-by-Step Guide
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Cool Audi A4 B8 S line Bumper Removal / RS4 Grille Fitment Step-by-Step Guide
    Hi All,
    I fitted my new RS4 type Grille yesterday which involved me having to remove the front bumper and the original grille. I could not find any guides online relating to the B8 and the only similar one was for an A5 which has a slightly different bumper and was not a comprehensive guide. Therefore I decided to write-up my own guide with photos for each stage. Please excuse the quality of the photos as they were taken on an iPhone.
    I purchased the grille from seller tcboverstock on eBay:
    Audi A4 S4 B8 09-12 RS Style Gloss Black Mesh Front Hood Bumper Grill | eBay
    It cost £60.37 with £36.58 delivery which incurred a £12 custom & admin charge when it arrived in the UK from the US.
    The car involved was a 2009 S line. I cannot confirm if this guide would work for the SE bumper or the facelift model.
    **ANY PERSONS FOLLOWING THIS GUIDE DO SO AT THEIR OWN RISK AND I TAKE NO RESPONSIBILITY FOR ANY DAMAGE ETC. CAUSED**
    The time taken to carry out this task, was around 1.5 hours, but by following this guide it may be possible to do it quicker. I am not a mechanic and the guide is written as step-by-step guide for all abilities.
    Tools needed are as follows: (these can be purchased from Halfords)
    1x Torx t27, 1x Torx t26, 1x 3/8" Ratchet, 1x 3/8" 10" Extension Bar, 1x 3/8" 10mm socket, 1 x small torch (not essential), 1x small screwdriver, and some protective matting in front of the bumper.
    STEP 1: After opening the bonnet, remove the 4 bolts on the Airflow panel indicated below, using a t26.
    STEP 2: Locate the 3 plastic bolts indicated below.
    Push down on these plastic bolts.
    STEP 3: Remove the Airflow panel by pulling towards the engine bay and lifting upwards.
    The engine bay will now look like this once the Airflow panel has been removed.
    STEP 4: On the drivers side, turn the wheel inwards and locate the two bolts on the front edge of the wheel arch, as indicated below.
    Remove these 2 bolts using a t27.
    STEP 5: Peel back the wheel arch liner and locate the bolt, indicated below, which is located just below the headlight. (Note: A small torch might be useful in locating this bolt)
    Remove this bolt using the Ratchet with the attached Extension Bar and 10mm socket.
    STEP 6: There are 5 bolts located below the bumper. Remove these using a t26. (Note: There is a bolt located on the far edges of each side of the bumper. This is indicated on the left of the photo below. These bolts are different to the other 3 bolts so make sure you don't mix these up.)
    STEP 7: On the passengers side, turn the wheel inwards and locate the two bolts on the front edge of the wheel arch (exactly the same as what was carried out on the drivers side.) Remove both of these bolts using a t27.
    STEP 8: Peel back the wheel arch liner.
    Locate the bolt, as indicated below, which is located just below the headlight. (Note: A small torch might be useful in locating this bolt)
    STEP 9: Locate the two bolts on the top of the bumper, as indicated below.
    Remove these bolts using a t26.
    Use a screwdriver, lift the flange located underneath each of the two bolts. (Note: Be careful not to damage the paint of the bumper when using the screwdriver)
    STEP 10: Remove the Fog Light surrounds on either side by giving them a good pull outwards. (Note: This is not mandatory but I found it helpful for the next step)
    STEP 11: ENSURE THAT THE IGNITION IS OFF AT THIS STAGE TO PREVENT POSSIBLE FAULT CODES FLAGGING UP!
    Remove the bumper from the car by gently wiggling and pulling on all sides, fog light hole, and from top and bottom. (Note: this is where step 10 proves useful). Make sure that protective matting is in place in front of the bumper in case the bumper is dropped etc. Be aware that the bumper will still be attached to the car at this stage, via wires.
    STEP 12: Once the bumper is free, the airtemp sensor will then need to be removed from the bumper by gently pulling it free.
    STEP 13:
    Unplug the fog lights by using a screwdriver to unclip the socket.
    The bumper will now be fully free from the rest of the car at this stage.
    STEP 14: Place the bumper face down on the protective matting and locate the 12 bolts indicated below.
    Remove these bolts using a t26. The bottom bracket indicated below can be removed once the 6 bolts holding it in have been taken out. This bracket has to be added to the replacement grille.
    STEP 15:Unclip the 4 clips, 2 on either side of the top of the grille, using a screwdriver.
    STEP 16: Unclip the 4 clips, 2 on either side of the grille, using a screwdriver.
    Sandra likes this.
    2009 Audi A4 2.0 TFSI S line, Misano Red, 19" Black Edition Rotors, RS4 Grille, Sat Nav, AMI, Bluetooth, Phone & Voice Prep, CD Changer, Gloss Pack, Heated Seats, Cruise Control, Electric Folding Mirrors, S line Suspension, Dynamic Boot Spoiler, K&N Typhoon Induction Kit
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Cool
    STEP 17: Locate the 5 clips, 4 of which are indicated below.
    Unclip these clips by gently pushing down with a small screw driver.
    The grille will now become free from the bumper.
    STEP 18: Turn the grille over and locate the 10 clips on the back of the Audi logo.
    Unclip these clips by pushing the black clips attached to the grille, away from the chrome part of the Audi logo, using a small screwdriver.
    Once these clips have been unclipped, the Audi logo will now be free from the grille. This can be easily attached to the emblem holder of the new grille.
    Reverse these steps to attach the grille to the bumper and the bumper back onto the car.
    The Finished Product:
    NHN, seanick, viceroy and 6 others like this.
    Macdoon's Avatar
    Essex
    1,487
    Excellent write up pal, grille does look good in gloss. How is the grille now it's on, some are a wee bit flimsy.
    ScottishS3 likes this.
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler.
    viceroy's Avatar
    Aug 2011
    Johannesburg
    198
    Agreed.
    Excellent write-up.
    Can't believe how rusted all your screws are though. Not meaning anything by it as I understand UK weather is not the best.
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    700
    Visit SI-W85's Instagram Channel
    Again great write up, I will use this to remove my bumper for wrapping my grill. Car looks spot on with the new grill fitted.
    Custom stainless straight through quad pipe, S4 diffuser, EGR delete, stage 1 remap, window tints, coilovers with adjusters taken out, vag com mods, 25mm spacers, led interior lights, led number plate lights, painted callipers, calliper decals, pressed plates, black edition grill. Plenty more to be done.
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Thanks for the kind remarks. It's the first guide I have ever written. I just hope it can be of some use to other people.
    Grille is solid and very well made. I avoided the all mesh grilles as I had heard they were very flimsy. Plus with the crash beam cover built in like this one (the same as the RS4 incidentally), I didn't need to paint the crash beam.
    Some of my bolts are quite rusty and I'm in the process of cleaning up the visible ones in the engine bay and painting them. The salt used on the roads here in the winter, doesn't help things.
    Macdoon's Avatar
    Essex
    1,487
    Quote Originally Posted by ScottishS3 View Post
    Cheers pal. trawling ebay as we speak lol
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    700
    Where did you get the grill from?
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Quote Originally Posted by Macdoon View Post
    Here's where I got mine:
    Very quick delivery and excellent correspondence from this company. Highly recommended.
    It also came with all fittings and optional front parking sensor brackets.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,313
    Excellent write up Ewan, it totally transforms the car. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    700
    Bloody hell that is cheap, just one thing what is that behind the top part of the honeycomb I can see some plastic behind the grill?
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Quote Originally Posted by SI-W85 View Post
    That is built into the grille. The RS4 has it as well and as this is a copy of the RS4 grille, it has it as well. It might have something to do with airflow. You don't notice it when it's on the car. I think it's only noticeable because of the angle I took the photo at. The same with the crash beam cover built into the grille. You don't notice it when it's on, because of the gloss black paint,
    Dec 2013
    81
    Great post, one to bookmark
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    700
    Yeah true prob is just camera angle, looks good on the red car anyway, will u be wrapping the bottom grey bit on the bumper?
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Don't give me anymore ideas! lol. Hadn't really thought about it to be honest.
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    700
    Haha get it done will just finish it off nicely, shouldn't be hard to do and the wrap to do it will prob only cost around £10.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,931
    Quote Originally Posted by Sandra View Post
    anychance it can be a sticky ?
    A4B8Sline's Avatar
    Jan 2012
    Exeter, Devon
    135
    Great write up mate. Grille looks ace!
    Dec 2013
    Portugal
    32
    Follow X_Splinter On Twitter Visit X_Splinter's Youtube Channel
    Excellent tutorial of great value to the audi modding community
    +1 for it be sticky (or maybe a section for guides in forum )
    ScottishS3 and BigGreg like this.
    Truth is Engineering
    Point_Audi's Avatar
    Vorsprung durch Technik
    May 2010
    Ireland
    419
    As the guys and girls have said mate fantastic guide, thank you for taking the time to put it together. It will most definitely come in useful! .. Should be a sticky!
    A4 B8 2.0TDI S-Line Executive
    JG51 AUD's Avatar
    Jul 2013
    North Ayrshire
    384
    +1 Sticky.
    Jun 2006
    20
    Just my 2p's worth... In fact, I'd have to see it first.
    Could one of you Photoshop whiz kids see what it would look like with the four rings in black?
    This could possibly make it that bit more aggressive.
    allanmb's Avatar
    Feb 2014
    78
    I wonder is there an RS4 style grille for the B8.5?
    Audi A4 2.0TDI Quattro 177PS Black Edition (B8) in Brilliant Black, B&O sound system, MMI plus satnav, Parking System plus
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    700
    Quote Originally Posted by allanmb View Post
    Yes there are plenty on the market for an B8.5.
    allanmb's Avatar
    Feb 2014
    78
    Awesome! Then I might just do this mod once the weather improves
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Here's another one:
    ivor1, sammi and THQuattro like this.
  28. #27
    Macdoon's Avatar
    Essex
    1,487
    That looks the mutts ......grille is on the ever growing mod list lol, very hard to find in gloss tho'
  29. #28
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Thanks mate! Yeah it was really hard to find one in gloss. In fact that is the only gloss grille I have ever seen that with the built in crash beam cover. I have seen the all mesh ones in gloss from China but I have heard people say how flimsy they are.
  30. #29
    BigGreg's Avatar
    Feb 2014
    59
    Stunning write up. Think the job is beyond me but, as the bumper needs to come off for the timing belt change, can't think of a better time. Now the search is on for the same grill with chrome surround.
    Now: 2008 A4 Tdi 170, B&O Sounds, Full Leather & 19inchers & 2009 VW Golf 1.4 Tsi
    Gone: Mondeo 2.5t Titanium X Estate, BMW X5, ST220, Impreza Turbo, ST24, Volvo 855R, Volvo T5, Rover 220t Coupe, VW Golf GTi x2, Escort RS Turbo Series2, Ford Capri 2.8i, Opel Manta GTE, Fiesta XR2 Mk2 and my first Car Ford Escort XR3i in black!
  31. #30
    BigGreg's Avatar
    Feb 2014
    59
    Ok struggling to get a grill. Any ideas, tried you ebay link but they don't have them anymore. Black with silver trim with crash been cover preferred. Thanks.
  32. #31
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Quote Originally Posted by BigGreg View Post
    He is the only seller with the gloss black grilles. Try messaging him on eBay. Remember to open your search options to Worldwide on eBay and you will get a lot more choice.
    BigGreg likes this.
  33. #32
    Cyprio's Avatar
    Jun 2013
    Colchester
    96
    Just read this thread - a bloody excellent step-by-step guide that!
    MY2014 Ibis White S4 Black Edition
  34. #33
    JG51 AUD's Avatar
    Jul 2013
    North Ayrshire
    384
    RS4 grill received today from same seller as ScottishS3, must say the quality looks very good indeed, weather permitting I'll be fitting it within the next couple of weeks, haven't made up my mind whether to keep it gloss black or go matt plasti-dip. Got the chrome door surrounds wrapped matt black, so probably go matt, I can always peel plasti-dip off if I don't like it.
    Cheers to ScottishS3 for the seller info and this gr8 bumper/grill removal guide.
    JG
    Macdoon and ScottishS3 like this.
    2008 A4 B8 2.0 TDI - with a difference!
  35. #34
    ScottishS3's Avatar
    May 2011
    Moray
    1,406
    Quote Originally Posted by JG51 AUD View Post
    JG
    Cheers mate!
    Make sure to post some pics up when you fit it! Any problems, let me know and I will only be too happy to help.
    Incidentally, have you got any pics of your wrapped window surrounds? If you don't mind me asking, how much did it cost to get done?
  36. #35
    JG51 AUD's Avatar
    Jul 2013
    North Ayrshire
    384
    Cheers mate!
    Will defo post some pics mate, undecided as to plasti-dip it now, may just put it on and take it from there, I've already plasti-dipped existing grill while still on the car, so shouldn't be any probs doing RS4 one.
    Re. wrapped window surrounds, got it done for £50, bargain, as the guy who done it wasn't busy, time of the year and all that. I'll post some pics for you tomorrow after work mate. Oh and cheers for the offer of help if needed, if I get stuck, I'll be in touch.
    Cheers JG
  37. #36
    JG51 AUD's Avatar
    Jul 2013
    North Ayrshire
    384
    Here you go ScottishS3
  38. #37
    Macdoon's Avatar
    Essex
    1,487
    John, car is looking sweet now pal, big difference from last year eh
    JG51 AUD likes this.
  39. #38
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    700
    Been playing with mine today too lol this guide came in handy had the bumper off and grill changed in less than 30 mins
    ScottishS3, JG51 AUD and A5BlackEd like this.
  40. #39
    JG51 AUD's Avatar
    Jul 2013
    North Ayrshire
    384
    Cheers Mac, it's getting there.
    How's your's coming along?
  41. #40
    JG51 AUD's Avatar
    Jul 2013
    North Ayrshire
    384
    SI-W85, do you want to do mine, lol.
    SI-W85 likes this.
  1. Audi s3 facelift bumper including black optics grill, pics enclosed.
    By brealy in forum For Sale/Wanted - Audi Parts
    Last Post: 29th November 2011, 14:06
  2. Audi A4 dtm grill fitment
    By hon in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th March 2011, 10:08
  3. removing grille to replace audi badge
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th April 2010, 18:05
  4. Audi A3 front bumper with grill
    By stevehsv868 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2008, 20:39
