Chris NottVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 49
Like Tree11Likes
Thread: Cheap but effective modification and completed in 10 minutes!
    Point_Audi's Avatar
    Vorsprung durch Technik
    May 2010
    Ireland
    430
    On my last Audi A4 B6 model I changed the water pistol jets to the fan version from the VW Passat. I was quite surprised to find that Audi are still using the water pistol version, so I decided to change them in my B8 model.
    Not sure if this would be something anyone would consider on the B8 model, but trust me the difference is unbelievable. They fitted perfectly so straight swap and just to adjust the spray angle.
    Just thought I would create a post to give other B8 owners a modification to maybe consider!
    A4 B8 2.0TDI S-Line Executive
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,980
    part numbers please ?
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Sure no problem, the part numbers are as follows:
    Heated Fan Jets - 5M0955986C
    Non/Heated Fan Jets - 5M0955985C9B9
    Here is a link where I originally got the idea, great modification!
    http://www.audifans.net/ftopict-25499-.html
    bez101's Avatar
    Jul 2008
    7,980
    iv done the b6/b7 in the past
    do you have to glue the B8 ? same as the b7
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Nope the B8 its a straight swap perfect fit no glue required!
    benjie likes this.
    bez101's Avatar
    Jul 2008
    7,980
    nice one will order monday
    cant be arsed with the glue
    Point_Audi likes this.
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Yea it was a pain now, glued my hand also!lol
    bez101's Avatar
    Jul 2008
    7,980
    Quote Originally Posted by Point_Audi View Post
    Audi A4 'Water Pistol' to VW Passat 'Fan Jet' Conversion.... - Audifans.net
    in that link it says the heated ones are 9b9 ?
    have you put the part numbers the wrong way around ?
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Nah I don't mate, I made that mistake also when ordering! The heated ones I have on matches what I have in my thread! They changed the part numbers slightly from what I understand.
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    699
    Visit SI-W85's Instagram Channel
    Great I have thought that the audi ones are poor considering so many other cars have the fan jets which seem much better, maybe the screen wash will last a bit longer now as it seems I need to constantly refil mine, will order some which ones would you say to get??? Cheers
    Custom stainless straight through quad pipe, S4 diffuser, EGR delete, stage 1 remap, 19" staggered X5 wheels, G23 custom adaptors, stretched tyres, window tints, coilovers with adjusters taken out, vag com mods, led interior lights, led number plate lights, painted callipers, calliper decals, pressed plates, black edition grill. Plenty more to be done.
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Yea they are very poor now! .. Funny I thought the same thing always refilling mine also, maybe the headlight washers don't help!lol .. Check to see which ones you have at the moment, two ways see if there is any wiring running into the bonnet at either side when you open the bonnet. Or check by popping one off, very easy, i would check first!
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    699
    Yeah will do cheers did you get from audi or elsewhere?? Cheers
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    I got mine from VW mate, Audi might be able to order them for you also!
    Jul 2013
    111
    I read elsewhere people struggle to get the spray high enough when changing to the fan type
    How high does yours hit the screen?
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    I haven't had any problems John, they spray high enough for me now!
    Jul 2013
    111
    Ok cheers mate
    How much are these? Not sure if I need heated or not will have to check
    Sep 2013
    10
    I like the look of this mod, on my S4 the jets are rubbish, and the drivers side jets need adjusting anyway
    I have had a quick look for the parts for this mod and the heated parts are £21 each off ebay -can anyone find them cheaper ??
    Will have a quick look under the bonnet later on, and might give this mod a go
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Im also tempted by this... My concern though is even with the standard jet type the pressure isn't very high and they struggle to give good coverage. Not sure if its a weak pump or if the system is slightly blocked?
    Has anyone else experienced this?
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    A friend of mine got them from a breakers for 15 quid for the pair (heated) and no problems with them!.. Can't say I have experienced that tbh mate, I will try to take a wee video later of them in action to let you see.
    May 2009
    south yorkshire
    569
    got mine from a vw passat same fitment
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Yea thats what you need to get them from, perfect fit.
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    699
    If they are non heated is there a way to make them heated or is it not worth doing?? Would be good to post a vid of this mod to see what kind of coverage it gives on the window before we all go out and do it lol
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    I would say there might be a way to add the wiring for heated but honestly can't see it worth the hassle unless its really really cold weather, usually the heat of the engine does the trick. I will dig out the link from my last car to show the difference and will try to get a short video of them for you on thr B8.
    Jul 2013
    Swansea, Wales
    158
    took me a while to wonder what the hell you were on about with "piston" and "fan" (thought it was the water propulsion method at first...not the spray style haha!!!)
    deffo be putting this mod on the list out of curiosity.... with regards to nozzle adjustment, is it just a vertical alignment or can they be rotated/aimed left/right? reason I ask is just on my car (not audi ) each jet has 3 nozzles so they are set up to fire at different heights of the screen to give better coverage when motorway driving. also kinda wondering if you could have an angled spray like ? "/ \" ...maybe not that extreme angle but you get the idea
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    699
    The thing with the fan type spray if you angle it towards the top of the window it gives good coverage on the window from top to bottom anyway it is a lot better way if you ask me why Audi don't do it seems a bit poor to me...
    Jul 2013
    Swansea, Wales
    158
    they should design nozzles to spray the audi logo on the screen xD
  28. #27
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Its just a vertical alignment I am afraid, but as SI-W85 said you angle it towards the top of the window! It beats me also why this isn't something Audi fit as standard!.. DrSasso that would be class!lol
    Since a few of you guys suggested maybe taking a video to show them in action I have done one before and after along with a few snaps for you to have a nosy!
    I am very impressed with them now, the coverage is excellent imo!
    Enjoy!!
    Before
    After
    DrSasso likes this.
  29. #28
    Dec 2013
    81
    My Skoda Superb had fan jets too, so the Skoda part could be another source for them.
  30. #29
    Viking's Avatar
    Mar 2010
    209
    Also fitted to the Seat Alhambra 2011 - 2014, Skoda Superb 2008 - 2014, Skoda Yeti, VW Eos, and most later VW models. Beetle, Caddy, Golf, Golf Plus, Jetta, Passat, Scirocco, Sharan.
    Don't blame me for your ignorance and stupidity. It's entirely your own doing, and nowt to do with me.
  31. #30
    ScottishS3's Avatar
    May 2011
    Moray
    1,416
    Well I'm not near my car so could someone please tell me how many I would need 1 or 2 and heated or non-heated?
    Wheres the best place to buy them from?
    Many Thanks
    2009 Audi A4 2.0 TFSI S line, Misano Red, 19" Black Edition Rotors, RS4 Grille, Sat Nav, AMI, Bluetooth, Phone & Voice Prep, CD Changer, Gloss Pack, Heated Seats, Cruise Control, Electric Folding Mirrors, S line Suspension, Dynamic Boot Spoiler, K&N Typhoon Induction Kit
  32. #31
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    You need two and its hard to say if you need heated or not, you will need to check this yourself. I think since yours is an S-Line they might well be heated. But I can't say for sure.
    You can get them from VW, Seat, Breakers or TPS. If they are heated then perhaps a breakers would be better as they are a bit expensive from the dealer.
    ScottishS3 likes this.
  33. #32
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    699
    Mines an sline but they they aren't heated so I would check for yourself...
  34. #33
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Yea as I said I wasn't too sure!lol .. I would definitely check yourself will only take you a few minutes but better to be sure! .. Strange though, wonder was it an additional option!Hummm
  35. #34
    Jul 2013
    Swansea, Wales
    158
    thanks for the response and the vid. the coverage difference really makes you wonder why everyone isn't using fan sprays could have done with the heated ones this morning, bit icy!!! cleared the screen, drove off...did the wipers about 50 yards down the road (without water) and it basically covered the screen in ice again in a thin sheet xD DOH!!!
  36. #35
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    699
    It will be an additional option as with everything on Audis lol even silly things like door lights I mean wtf that should be standard for safety reasons, sun visor lights and glove box, foot well I think its crazy that an s line especially doesn't come with those lights as standard...
  37. #36
    ScottishS3's Avatar
    May 2011
    Moray
    1,416
    How would I be able to tell if they were heated or not?
  38. #37
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    No problem at all, its good to see it in action gives you a better idea of the difference! .. It certainly was icy this morning, heated is very handy! ..
    I totally agree, the glove-box light is what annoys me the most, for such an expensive car and as you said with it being S-Line it should have more extras as standard.
    You can see if there is any wiring running into the bonnet either side, or pop them off and you should see a wire going into the washer itself. Two seconds to pop off!
  39. #38
    Dec 2013
    81
    It would appear that Lamborghini use them too.
  40. #39
    Point_Audi's Avatar
    May 2010
    Ireland
    430
    Funny I seen that!lol Be class to say you have the washer jets off a lamborghini!lol
    JG51 AUD likes this.
  41. #40
    Jul 2013
    111
    Just checked mine and they are heated. Which other cars/ spec are likely to have heated fan type?
  1. Glow plug light and complete power loss
    By norm29 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2011, 12:15
  2. Simple but effective.
    By Sandra in forum You Tube Links
    Last Post: 28th October 2010, 21:29
  3. Cheap but good quality car cleaning gear!!!
    By ozmallet in forum Detailing
    Last Post: 20th October 2010, 19:39
  4. Standard 2008 S3 Suspension and Complete exhaust for sale
    By pontias_s3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2009, 21:00
  5. cheap holiday going, me and the boys went last year!
    By David in forum Jokes, Games & Humour
    Last Post: 20th September 2008, 19:07
