EM TuningAH Fabrications
    gareth2689's Avatar
    Jan 2014
    Northern Ireland
    6
    Seatbelt Light & passenger door lock!
    This is my first post on the forum so first off I would like to say Hi!
    I recently purchased a Grey 2008 Audi A4 SE 2.0TDI 120. Great car and absolutely love it! Came with FASH, full years MOT, 4 new tyres, two owners from new (2nd being a woman) and I got it for good money.
    When i bought the car i knew that there was a fault with passenger door lock. When you lock the car the passenger door will lock but when you unlock it the door won't open.
    You can still open it from the inside and once you do that you can open it from the outside. But as soon as you lock and unlock it you can't open it from the outside again.
    From reading some threads on forums I believe it is just the door lock. Is this a common problem with B8 A4's? Can I just buy a new lock from Audi and fit this? Or does it need coded to the other locks in anyway?
    OK so I thought that was the only thing wrong with the car until a few days ago. I had the car valeted inside (wet vac on the seats) and two days later the seat belt light won't go off.
    At first it was intermittent and if you unplugged driver seat belt and plugged it in it would go off but today it is just constantly on and the chime is quite annoying.
    Could the wetness from the valet have damaged something in the seat? I checked the connectors under the seat and they are all fine.
    I have read on some threads that the buckles can sometimes go? could this possibly be it?
    Any help would be great. Thanks!!
    2008 Audi A4 SE 2.0TDI 120 - Grey
    27,073
    Welcome to the site.
    Check under the seat, maybe they've disturbed the seat belt warning connectors, if all connected, check for any water ingress.
    It should just need the lock swopped over, shouldn't need any coding.
    gareth2689's Avatar
    Jan 2014
    Northern Ireland
    6
    Thanks NHN
    Yes checked the connectors, all seem to be fine. The connector that runs to the seat belt buckle, is this solely for the warning light and chime? Would it be possible to disconnect this to stop the chime until i find a permanent fix for this?
    Great i will get lock off Audi before the weekend and fit it.
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,970
    YES.....also anyone with vcds can disable the chime
    Quote Originally Posted by gareth2689 View Post
    Thanks NHN
    Full leather/19"wheels/cruise/
    gareth2689's Avatar
    Jan 2014
    Northern Ireland
    6
    So just an update.
    Fitted the new lock over the weekend. And door works perfectly now.
    Not a hard job to do if you have some DIY knowledge. Took me about an hour to do. (Just be careful when removing door card that you don't break any clips)
    Disconnected the seat belt plug under the seat and no longer have the chime. A new seat belt plug off Audi is £54 which isn't too bad though I am quite liking not having the annoying chime so won't be in a rush to buy one.
    Thanks for your replies and help with this!
  1. 2.0 tdi passenger door lock fault 3 door 2007
    By WALTO TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2013, 22:44
  2. Rear passenger door lock has a mind of its own
    By GavConner in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th July 2013, 12:24
  3. Passenger door lock change
    By choimaloy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2012, 00:22
  4. passenger side door lock not engaging...wreckin my head!!!
    By tullA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th March 2012, 22:23
  5. Rear passenger door locking
    By lscolman2 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th March 2011, 14:57
