Volks AutosBadger5
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Intermittent door lock fault - finally fixed
    Just a quick post it's not really a guide but it may help a few as this problem seems pretty common.
    Symptoms
    When unlocking the car with your fob, in my case all doors open bar the driver (typical).
    If the key is then used to unlock the drivers door it then opens.
    It doesn't happen all the time mainly if the car has sat for a few hours locked. The car will always open from the inside.
    Solution
    I tried replacing the control module (little black box which controls most electrics in the door) as vcds pointed to this but it wasn't actually the problem because shortlydown the line it started again.
    So I stripped the door down to get access to the mechanicals of the lock.
    You need to remove the exterior door handle, door panel and a smaller inner panel. All quite simple to remove and guides can be found easily.
    Once you have the lock out (take car not to kink either of the two cables!) it should look like this, in the picture that is the operating cable for the exterior handle.
    Remove the grey cover to expose the lock mechanicals as so.
    You should see the that the grease applied from factory has clunked/dried up. I thoroughly cleaned the unit and re greased all mechanicals
    Touch wood, so far I haven't been shown up and got my key out to open my 2008MY car lol
    Hope this helps
    Nov 2012
    S Wales
    11
    Hi Jamie,
    This is exactly what's happened to my A4 Avant. Have you got a link to show how I can take off the door handle, and door trims.
    Would I need any special tools to get the job done?
    Tony
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Some interior trim removal tools as such come in handy
    9 Piece Upholstery Trim Removal Tool Set to Remove Car/Van Interior Door Panels | eBay
    Door panel removal can be found in this thread
    Audi A4 B8 Door Warning Light and Puddle Light retro fit
    Door handle removal can be found in this thread
    Door handle swap and sensor removal - A5_OC
    Nov 2012
    S Wales
    11
    Thanks Jamie,
    I will give this a go in the next week or so and let you know how I get on.
  1. 2.0 tdi passenger door lock fault 3 door 2007
    By WALTO TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2013, 22:44
  2. New VCDS Cable - Door Locking Fault ??
    By Tinners in forum VCDS (formerly VAG-COM) forum
    Last Post: 25th October 2012, 13:15
  3. New VCDS Cable - Door Locking Fault ??
    By Tinners in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2012, 21:29
  4. door trim and lock strip corrosion fix
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th April 2008, 12:17
  5. Door lock, windows fault
    By in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2005, 17:15
