AH FabricationsJMB Retrofits
    Anthony566's Avatar
    Nov 2013
    North East
    602
    The Blackvue DR550GW - Front & Rear Camera installs
    I have posted in the camera section but wanted some feedback from A4 owners that have either installed this system or had it installed for them .
    If you had it installed then can you say who and were this was done ??
    Thanks in advance.
    Since posting this I have done a lot more digging around and have found the following :-
    The front camera is 1080p @ 30 fps
    The rear is 720p @ 30 fps
    There seems to be some questions over the bit rate of the recordings and the sharpness of playback, also there is a now known issue with interference with DAB radio as the rear camera av cable is not shielded.
    I am hoping that Blackvue change the AV cable two one that resolves the interference issue and releases a firmwear update to deal with the bit rate question.
    Having looked around a lot this week this system seems to be very well designed and on paper has very impressive specs but just needs some fine tuning.
    Aug 2012
    31
    Im also interedted in this especially night or dark recordings (rear) as they dont have any night ir's
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    I've installed the HD version in my Q7, took 30 mins to do and all plumbed in with the Power Pro adapter. Quality is excellent and it fits nicely behind the rear mirrror
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    May 2013
    32
    Anthony566's Avatar
    Nov 2013
    North East
    602
    There have been a few updates on this, there is a new cable for this unit that should fix the interference problem and a firmware update
    New Coaxial cable for Blackvue DR550GW-2CH
    New Coaxial cable for Blackvue DR550GW-2CH | Blackvue UK News & Blog
    New firmware 1.021E released for DR550W-2CH
    Fixed summertime error
    - Reduce microphone noise
    - Image tuning
    - System stabilizing
    so if the new cable does resolve the interference problem then I will get one of these units installed.
    2013 A4 2.0 TDi 177 quattro Black Edition - Glacier White
  1. Blackvue DR550GW 2 channel in-car camera installation
    By Helifella in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2014, 16:45
  2. Blackvue DR550GW 2 channel in-car camera installation
    By Helifella in forum In-Car Camera Technical
    Last Post: 2nd November 2013, 19:37
  3. The Blackvue DR550GW - Front & Rear Camera
    By Cruiser89 in forum In-Car Camera Manufacturers
    Last Post: 7th August 2013, 00:00
  4. Fitting in car dvr with front and rear cameras
    By Patrick_c99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th June 2013, 21:48
  5. How do i remove the front and rear bumpers
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2005, 16:37
