Chris NottVolks Autos
Results 1 to 7 of 7
    Feb 2013
    Hampshire
    44
    Tyre pressure confusion
    Hello,
    I checked the pressures on my 245/40R18 tyres yesterday and set them to the Audi recommended pressures from the drivers door at 41 PSI front, 36 PSI rear. This is for the lowest weight three people. I decided to check a few websites to see what pressures they recommended and got the following results
    Front Rear
    AA 32 30
    Qwikfit 31 30
    Tyresafe 32 30
    National Tyres 32 30
    QI (normal) 32 30
    (heavy) 35 39
    There are more but you probably get the picture. All these sites correctly identified the car and tyres from the Reg no. I'm really tempted to lower my tyre pressures. Is there a reason Audi's recommended pressures are so high? I know my spine would agree.
    Mar 2013
    12
    Which model do you have exactly? I have the same tyres and the sticker on the door recommends 32PSI on the front and 29 at the rear?
    Feb 2013
    Hampshire
    44
    Its the 3.0TDI Quattro. Feels a bit hard.
    Gavin0478's Avatar
    May 2010
    cleveland
    443
    Firstly look at how the tyre's are wearing and secondly how the handling feels.
    If the tyres are wearing more towards the outer edges hopefully your tracking is ok but that means the pressure is too low so all the weight is on the shoulders and the tyre's will shuffle giving a woolly steering response.
    If they are wearing more in the center they are too high and ballooning out this will give a skittish ride.
    Its finding what suits you more to be honest.
    V8 baby... oh yeah
    Mar 2013
    12
    Quote Originally Posted by Stonefish View Post
    I have a 2.0 TDI, so obviously yours is going to be heavier, but would the weight difference really warrant an increase in 10 PSI? Seems pretty high!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,852
    Just drop them and see how they feel, they are only 'recommended' tyre pressures. On My Passat Estate TDI, I run 32 front 35 rear, I drop the rear pressures if I'm carrying passengers long distance. Just play around with them until you feel it's right.
    You've got to have a laugh!
    Feb 2013
    Hampshire
    44
    Thanks for the replies. I will try dropping them a bit and see how it handles. Definitely seems a bit frisky on bumpy roads in the wet.
  1. Confusing tyre pressures
    By Duggy72 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 15th March 2013, 12:21
  2. tyre pressures
    By carl310166 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2004, 15:46
  3. Tyre pressures
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2004, 08:39
  4. TYRE PRESSURES
    By wezhaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2004, 08:06
  5. Optimum Tyre pressures
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th May 2003, 13:37
