Chris NottBadger5
Results 1 to 7 of 7
    mpc
    May 2013
    61
    2009 A4 Avant S-Line - Brakelight Bulb Replacement?
    My drivers side brake light is out and i'm trying to find out if it's a straight forward fix. The owners manual only describes a boot style rear and not estate.
    Is there any info on how to do this?
    A4B8Sline's Avatar
    Jan 2012
    Exeter, Devon
    173
    In your boot you will have a access door on each side of the boot. Pull down the drivers side and look in and back towards the light. Have a look for a plastic nut and undo. Once it's off your light cluster will pull off the rear of the car. Once released unplug the cable on the back of the unit. You can then change the bulb. It goes back the same but in reverse. Once you dig around it's quite self explanatory.
    mpc
    May 2013
    61
    Quote Originally Posted by A4B8Sline View Post
    Many thanks, I will have a look and try this myself...
    mpc
    May 2013
    61
    I had a look and can see the plastic bolt that needs undoing. When I get the cluster out - how do I know which bulb is the brake light as it appears there are about 3 bulbs in there?
    Aug 2011
    196
    Quote Originally Posted by mpc View Post
    Perhaps the one which doesn't illuminate when the lights and indicators are on and you press the brake pedal?
    mpc
    May 2013
    61
    haha, i was waiting for the smart alec question! Bit difficult to see when you are by yourself tho. Just thought someone may have known before I remove the cluster.
    Jul 2013
    Swansea, Wales
    191
    hehe made me chuckle xD this is where a small umbrella comes in handy....or anything really that you can put on the brake and wedge up against the seat
    or you could use a multimeter if you have one to hand and check the resistance between the contacts. If there's resistance the bulb works, if none then it broke :D but give it a shake as it might be just touching even though it's broken.
  1. Sunderland Newbie - 2009 A4 Avant S Line 170
    By StuF in forum The Welcome Section
    Last Post: 7th February 2013, 09:03
  2. Rear bulb holder O/S avant s-line,
    By John@mk in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th November 2012, 15:30
  3. audi a6 avant, problem with oil low level light, and bulb replacement
    By darcar in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th December 2011, 17:35
  4. How do I replace the rear window brakelight bulbs? (Saloon)
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th July 2009, 23:17
  5. Reg plate light.. bulb replacement?? 2003 Avant
    By imported_larry1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2006, 13:49
