Results 1 to 24 of 24
    Jul 2013
    107
    Tdi oil pump drive
    Just wondered if you guys are aware of these wearing and causing oil pump failure ? Mine is in having a service and a new drive as a precaution . My friend who is a ex vw master tech who now runs his family business was telling me the horror stories from when in vw .
    The part is about £8 but sadly 5 hours to fit it and he recommends.it being done every 60/70k
    Mk1 2l 16v track hack - gone
    mk2 gti 8v - gone
    mk2 gti 2l 8v - gone
    mk2 vr6 show car - gone
    mk3 Ibiza Cupra - gone
    mk5 gti big turbo - gone
    clio 172 - gone
    land rover discovery mud plugger - gone
    a4 sline avant
    passat fishing hack
    27,096
    Really, on a B8, I only know of the previous chassis being so problematic.
    Jul 2013
    107
    Yeh b8 . The early drives are hollow and the later ones are solid and hardend . I'm picking up the car tomorrow so will grab the old drive
    mk2 gti 8v - gone
    clio 172 - gone
    a4 sline avant
    passat fishing hack
    May 2009
    south yorkshire
    628
    your missing the half of it , if your mate knows his stuff then he will know that vw/audi changed the whole oil pump drive part for a newer one . i bought the part myself at a cost of £250 exchange ,the part you are buying is just a plain old allen key with the end cut off basically .and yes it does have a hole in the old one but it does not cure the problem that i can guarantee .
    the new drive and key are modified the key is 100mm long where the old one is approx 75mm long ,the drive is redesigned so that the keyway is alot deeper and the key is a very tight fit .
    old design only allows key to insert around 10-15mm and is loose even when new . my advice would be to fit the whole new part ,you have to do the same amount of work to get to it . and the new part has a lifetime unlimited mileage warranty against failure .
    Jul 2013
    107
    So what did you get for £250 ? A new oil pump or drive ?
    mk2 gti 8v - gone
    clio 172 - gone
    a4 sline avant
    passat fishing hack
    May 2009
    south yorkshire
    628
    for the £250 now £225 you get the allen key plus the new balance shaft ,you need to change both these parts for it to be bullet proof .
    ive honestly seen a 6mm allen key cut down and used as a bodge on the older b7 models .
    have a look on ebay for balancer shaft repair
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    thort thes tdi cr engines were bullet proof !
    Quote Originally Posted by hollow View Post
    Full leather/19"wheels/cruise/
    May 2009
    south yorkshire
    628
    Quote Originally Posted by vw754 View Post
    so did everyone else ,but they aint !!!
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    anyone know how much all this costs,any pics of the item,any symptoms/mileage/year?
    May 2009
    south yorkshire
    628
    replacement parts cost £225 ,no idea what they will charge to fit in your neck of the woods . symptoms are low oil pressure light on
    mileage 80,000 upwards.
    look on kmbpartsdirect and look at the balance shaft kit
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    so if low oil pressure light ever comes on...stop engine and get em done?
    sell mine before 80k lol only on 60k yet and i only drive 6-7k a year
    Jul 2013
    107
    It's 5.5 hours work as the subframe has to be removed . And as with any oil light turn the car off that instant
    mk2 gti 8v - gone
    clio 172 - gone
    a4 sline avant
    passat fishing hack
    a43.0v6tdi's Avatar
    Oct 2013
    17
    What engines does this effect?
    May 2009
    south yorkshire
    628
    the tdi common rail engines in the b8 made before sept 2009
    a43.0v6tdi's Avatar
    Oct 2013
    17
    Sorry to be potentially thick here but would that extend to the b8 '08 3.0 V6TDI also?
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    never heard of issues with the 3.0 tdi....but there are issues with the auto box's that many 2.7/3.0 tdi come with a lad i know had his tt one done twice,a4 one done 4 times! first time at 13k miles last one after 60k
    Quote Originally Posted by a43.0v6tdi View Post
    May 2013
    32
    I have an 2008 mod A4 B8 With the 2.0 TDI going on 170 000 km now.
    One more thing to worry about.
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    Quote Originally Posted by offpist View Post
    that around 106k?..........im not worried,mines just turned 60k.........plenty on sale on e-bay ranging from 50k to 188k.........im sure they all NOT had the failure.
    Apr 2010
    346
    RESURRECTION.......
    is this the same engine that is in the late 2008 vw passat ?
    May 2009
    south yorkshire
    628
    yep and its crap ,also happens on the early common rail engines too.
    Dec 2008
    North Yorkshire (Gods Country)
    26
    Add Jenno on Facebook
    Anyone know if a mid 2009 A4 2.0 143 engine code CAGA is affected ?
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    Yes.........dont worry im in same boat....not many b8's plent for sale on e-bay upto 190k on them when i searched all 2008/9 models.........ive stopped panicking mate,plenty of rumours,but who knows how theyve been maintained?
    Quote Originally Posted by Jenno View Post
    Dec 2008
    26
    Im told my A4 has the later Gear Driven Mechanism (registered May 2009) is this still affected ?
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    The rumour is yes........only safe after oct 2009....dont panic we have the same engine
  1. 2.0 TDI oil pump / balance shaft failure?
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1 Week Ago, 22:03
  2. following sticky 2.0 TDI oil pump / balance shaft failure? what year cars?
    By p1tse in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th April 2012, 17:24
  3. 2.0 TDI Oil Pump Failure?
    By danquattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2012, 11:08
  4. Early A3 170 CR - CBBB Engine Code - Oil Pump Drive Shaft
    By Craigy1D in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2011, 19:54
  5. 2.0 TDI Oil pump chain.
    Last Post: 23rd December 2009, 11:03
