Badger5Chris Nott
Results 1 to 15 of 15
    jerrygttdi's Avatar
    Flat oot
    Rogart Sutherland
    52
    S4 Winter wheels
    Can somebody please tell me what is the smallest diameter wheels that can be fitted to a 2010 S4 Avant. Thanks
    longp2's Avatar
    Mar 2011
    Tyne and Wear
    270
    Just fitted mine today, RS6 reps size 245/40 R18 which is the size shown on the door panel. I don't think 17" wheels will clear the brakes.
    Now on the drive - Lava grey S4 Avant Black edition, ADS, Sports Diff, Magma/black super sports seats etc...
    jerrygttdi's Avatar
    Flat oot
    Rogart Sutherland
    52
    Hi, Yeah I did wonder if the 17s would clear or not. Also wondered if you could get 18" steel's
    longp2's Avatar
    Mar 2011
    Tyne and Wear
    270
    I'm sure you could get some steels, try mytyres, I trawled eBay for a second hand set of OEM alloys but ended up going down the replica route and got the wheels with Dunlop 4ds for £1300 which is a lot cheaper than the quote that I got from Audi.
    jerrygttdi's Avatar
    Flat oot
    Rogart Sutherland
    52
    Cheers will try them
    mylo911's Avatar
    Jan 2013
    24
    18" is the smallest diameter that will fit a B8 S4, (17" won't go over disc & caliper) and you will most likely need to get a proper alloy rather than a steel.
    Audi recommend a 225/45/18 winter tyre for an S4, so an 18" x 8J or 8.5J alloy will be needed.
    I highly recommend www.felgenoutlet.de, a German company whom provide a huge range of winter alloy and tyre packages. Have just received a set branded alloys with Vredestein Wintrac X-treme tyres for £1100, including delivery to the UK.
    jerrygttdi's Avatar
    Flat oot
    Rogart Sutherland
    52
    Cheers for that mylo911
    gr4z's Avatar
    Jul 2013
    Stamford, Lincs
    88
    If you keep the factory fit wheels on an 2013 S4 what do you recommend for tyres? 225/40/18 or 245/40/18 (the same as the summers)?
    With the cold weather approaching want to get some ordered before my S4 arrives...
    Current: 2013 S4 Avant, Ice Silver, SS heated seats, tech pack, AMI, B&O.
    Previous: 2011 Mercedes C350 CDI Saloon
    longp2's Avatar
    Mar 2011
    Tyne and Wear
    270
    The label on the door recommends 245/40 R18 but 225s should be fine, if not better as they are narrower,
    gr4z's Avatar
    Jul 2013
    Stamford, Lincs
    88
    Will 225s be OK on the standard wheels?
    May 2013
    32
    I use 255/35-19 hakkapelitta R2 for my winter setup.
    jerrygttdi's Avatar
    Flat oot
    Rogart Sutherland
    52
    Aye, it's 19s that are on mine. But up here in the Highlands we get a fair bit of snow and the 255s are a bit wide.
    Oct 2013
    13
    Hi folks
    I have fallen foul of the Audi Offset / Centre Bore changes between platforms today, as I went out and tried my newly refurbed A6 Winter Wheels, on my A4 3.0TDI (sadly not an S4). Of course they don't fit Centre bore is wrong and I didn't even get to see if the offset is an issue.
    I have 4 good (2 x New, 2 x One Winter) 245/40 R18 tyres, and need some rims. I've been put off replica's in the past, but wondering if there's anything strong that can be recommended, or has anyone tried the BBS, Ronal or Borbet non-OEM wheels.
    I'm currently scanning eBay and all the Audi forums, but it looks like the wrong time to be searching - everything's getting snapped up and even tatty wheels at going are silly prices.
    Any suggestions?
    Nov 2013
    Heath Hayes
    951
    You can fit 17 inch wheels on the B8 S4 you just need the right wheel with the correct offset. The same as you can fit 16's to a 320mm brake setup the 345mm S4 is only 1 inch or 25mm larger.
    B8 S4 17'' winter wheels?
    There is only a few mm clearance on this setup between the balance weights and the caliper but it can be done.
    Karl.
    White220's Avatar
    White 220
    Sep 2007
    Aberdeenshire
    63
    Montecha, I got my oem rs6 wheels that I used on my b7 milled out to fit the New centres on my b8 s4. It was only about £200 for the four, which was good as they had to remove and refit tyres.
  1. Winter wheels for S3
    By anchorPoint in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th October 2008, 09:40
  2. Winter Wheels
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2008, 17:42
  3. winter wheels
    By mas in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2005, 22:15
  4. Winter Wheels on..
    By Lowride in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2005, 20:21
  5. What OE Audi wheels for winter wheels? Suggestions please.
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2005, 16:54
