Badger5AH Fabrications
Results 1 to 11 of 11
Thread: Pre heater
    Jul 2013
    107
    Pre heater
    Evening guys when I bought my car the previous owner said it has a pre heater and will warm the car up before I get in and go to work . Any ideas on what it's called and how to activate it ?
    dieseldoos's Avatar
    Apr 2013
    Hampshire
    137
    Im guessing your cars a diesel? If its is, the timer settings are via the MMI, (something like aux ventalation / heating - I am not in my car at present, but it is there) just set the time a short while before you are due to get in and leave, but it can kill the battery, hence I dont use it.
    2009 ​Audi A4 2.0TDI S-Line (143)
    Fully registered VCDS in Portsmouth & surrounding areas , and fault scanning of other makes.
    27,097
    Known as auxiliary heater, controlled via dis menu's aswell as a remote fob, subject to the system installed.
    Jul 2013
    107
    Cars in having a service but will check tomorrow .
    May 2012
    RETFORD, NOTTS
    1,753
    On the VW phaeton its a small one cylinder desel engine that just warms up the coolant to the cabin. On frosty mornings you still need to remember the engine coolant is cold and dont give it beans!
    Can be activated in the mmi or via vcds, one of those features that do not always come activated from the factory.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jul 2013
    107
    How do I activate this ? Had a quick look and can't find anything
    Mk1 2l 16v track hack - gone
    mk2 gti 8v - gone
    mk2 gti 2l 8v - gone
    mk2 vr6 show car - gone
    mk3 Ibiza Cupra - gone
    mk5 gti big turbo - gone
    clio 172 - gone
    land rover discovery mud plugger - gone
    a4 sline avant
    passat fishing hack
    27,097
    Unless its spec'd at build, it wont be fitted, so coding wont be of use, mostly fitted in Nordic countries.
    Jul 2013
    107
    Humm wondering if the previous owner was talking porkys ? As there is nothing on the mmi
    mk2 gti 8v - gone
    clio 172 - gone
    a4 sline avant
    passat fishing hack
    May 2012
    RETFORD, NOTTS
    1,753
    It can be activated with vcds.
    May 2012
    RETFORD, NOTTS
    1,753
    re-programming the Phaeton “auxilliary heater” to work as a “parking heater”
    1. Module 18 security access code 22106
    2. Adapt channel 09 to value 2
    3. Adapt channel 04 to value 0
    4. If the heater locks up, clear the error by adapting channel 03 to value 1
    Jul 2013
    107
    mk2 gti 8v - gone
    clio 172 - gone
    a4 sline avant
    passat fishing hack
  1. heater control valve
    By humlicek in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2003, 02:36
  2. Blown sub pre-out
    By Naresh in forum In-Car Entertainment
    Last Post: 30th October 2003, 20:48
  3. Heater problems
    Last Post: 24th October 2003, 13:33
  4. MOVED: David's Pre-Occupation with age
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2003, 22:20
  5. heater air flow Audi 80
    By Shane in forum Classic Audi Forum
    Last Post: 3rd August 2003, 22:05
