Sky InsuranceBadger5
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Noisy Heater/AC Blower Motor
    Recently I replaced the heater blower motor due it to packing up.
    Now with the new one installed I can hear it catching on the plastic surround up inside the dash.
    The old one didn't, so I examined both together to see if there's a difference which there isnt apart from tiny little metal clips attached to the fan blades. Weights for balancing I'm thinking? Set to each different dash from factory?
    I wander if there is a away to remove the fan blades from the old unit?
    Any input would be great, audi want £143 per hour inspection
    Jamie-S's Avatar
    Jun 2013
    Coventry
    279
    Seems to be sorted now using the old motor casing
  1. Heater / Blower Motor help needed
    By Steve_D in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2013, 17:26
  2. Noisy heater blower!!
    By SimonA3T in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2013, 15:08
  3. Heater Blower Motor
    By Forbzeeee in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2011, 00:02
  4. Heater blower motor fix
    By Mazza in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2008, 18:29
  5. What Blower Motors Fit
    By kbininger in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th February 2007, 18:35
