Sky InsuranceChris Nott
Results 1 to 10 of 10
Thread: Oil service
    Jan 2009
    Suffolk
    50
    Oil service
    Which oil service would be best for the car?
    Longlife or the standard one?
    I do about 13-14k miles a year.
    A4 3.0 tdi.
    Many thanks
    Rodders.'s Avatar
    Oct 2013
    94
    Long motorway journeys then longlife maybe, but your on the limit.
    Lots of short journeys, standard.
    Im basing this on what my petrol manual says. Im guessing diesel is the same, but you might want to check in the manual.
    Audi A4 Avant 2.0TFSI 2009 S-Line
    Phil-1's Avatar
    Sep 2013
    Harrogate
    894
    Mine has been on a long life service but now it will only do 4k a year and most of that will be around town with a run out at the weekends. Should I change to a standard service?
    Audi A3 8P Sport Back 170BHP (And I Love it)
    web page: philseagus.co.uk
    E-Mail:info@philseagust.co.uk
    Rodders.'s Avatar
    Oct 2013
    94
    I would for that distance. Mines been on longlife due to high millage, but now im on 5k a year ive swapped.Well i say swapped, i will when the longlife runs out in terms of service periods. I changed the oil myself when i got the car. Ill wait till the longlife runs out and get Audi to do the standard service. Means i had a cheap oil change doing it myself but i also keep full service history.
    Phil-1's Avatar
    Sep 2013
    Harrogate
    894
    I will do the same the long service is due in Feb. so will change it after then.
    Jan 2009
    Suffolk
    50
    I do about 30 miles a day round trip, up the A road.
    I called a local Audi garage and they advised they only do the longlife oil? They do not offer the standard one?
    Rodders.'s Avatar
    Oct 2013
    94
    Its the same oil for interim or longlife, which is why they say they only have the longlife oil, for example the Castrol EDGE 5W30 fully synthetic. Its longlife spec, but as you are making more starts and shorter journeys the oil is under more strain. So you change it more often for the interim service.
    Jan 2009
    Suffolk
    50
    Thanks Rodders for your explanation.
    A4B8Sline's Avatar
    Jan 2012
    Exeter, Devon
    135
    My mileage fluctuates each year so I have the car serviced either at - 1 year since the last or if I get to the long life mileage between services.
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    404
    I,ve stuck with the longlife service my car started with but I've just given it a extra oil and filter change myself in between services (castrol EGDE 5-30 and oem filter £32 all in) as I only use the car at weekends and holidays.I've just done the fuel filter as well as the cars just passed the 40k marker took all of 25min to do.
    58reg 2.0tdi 140(WAS) S-line Monza Silver withSUPERCHIP BLUEFIN
    S3 front grill/gloss fog light surrounds/rnse/gloss gunmetal wheels/EZ front spliter
  1. DSG oil service - Audi say No need!!!
    By AFN1980 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th April 2010, 10:45
  2. air bag light and oil service light
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2009, 11:49
  3. Changing from Variable interval oil services?
    By Nessy in forum Diesel forum
    Last Post: 30th April 2009, 07:51
  4. Oil Service on 07 2.0T FSi
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2008, 18:22
  5. OIL & SERVICE LIGHT SHOWING ON A3 MILEAGE METER?
    By turbodan in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2006, 10:04
