AH FabricationsBadger5
Results 1 to 13 of 13
    Aug 2013
    Loughborough
    12
    Automatic gearbox "slipping"
    Hi all,
    I'm after some advice before I go and book my car in at Audi (or contact the independent garage that sold me the car).
    My car sits on my drive which is on a slight incline, when I put the car into drive and start pressing down on the accelerator the car starts moving forward but when it hits a little more of the incline it stops moving and I have to apply more to the accelerator until the car decides to kick in and almost shoots out of the drive.....the gearbox oil was changed within the last 1000 miles and the car has covered 42000 miles...
    Any idea's\advice is greatly appreciated.
    Regards
    27,096
    You haven't told us anything about the car, engine type, gearbox type, year etc.
    Aug 2013
    Loughborough
    12
    Apologies,
    It's a 2009 A4 S Line Auto 2.0 TDI
    Mar 2013
    16
    Instead of it being a problem with the gear box, it could be the car trying to override the automatic handbrake? I'm guessing the car is fairly new, as this can sometimes take a bit of getting used to! I normally apply the handbrake doing very steep hill starts, and I experience what sounds like your description every now and then.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    I've noticed something similar with my 2012 3.0 TDI S-Tronic. I just assumed that it was the transmission slipping the clutch a little bit on the incline then once it realises it's on a slope it engages it more?
    If you end up taking it to Audi and that's not right it would be great to know...
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Aug 2013
    Loughborough
    12
    I did initially think it was something to do with the handbrake, maybe a slight delay from disengaging it, but as a test I disengage it, wait 10 seconds just to be sure and get the same result with the car coming to a stand still with a delayed\non responsive reaction to the additional acceleration.....
    I've owned several automatics (BMW X5, Mercedes C-Class, Lexus IS250) non of them with a gearbox that reacts like this....
    Jan 2013
    36
    I'm guessing your car is an 8 speed multitronic (so not a standard torque converter auto).
    2010 A4 3.0 TDI Quattro S-Tronic S-Line Sp Edition Avant
    Aug 2013
    Loughborough
    12
    yep I know it's an 8 speed not that I was aware that there were other versions...
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Mine is the 7 speed S-Tronic with the dry clutch and seems to behave very similar as I've said...
    Mar 2013
    16
    remember they have hold assist too, so even with the handbrake off on an incline, I guess it could give that impression?
    Jan 2013
    36
    I mentioned that it was a multitronic as the other auto cars you mention I think all use torque converter autos which are much better IMHO at manoeuvring speed tasks. Multitronic and torque converters work very differently. The early Audi multitronics got a bad press but I thought the latest ones were meant to be much more reliable
    The S-tronic is another type of gearbox again (effectively a manual with two clutches), and in my experience can also get confused by inclines when it is slipping the clutch. Not all cars have hill hold assist, I wish mine did!
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Yeah, mine seems to start the clutch slipping when it's moving forward. So essentially after any hill hold assistance...
    27,096
    Quote Originally Posted by dts439 View Post
    Check abs module for the coding option
  1. Automatic gearbox cooler/radiator
    By rhinopower in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2011, 17:18
  2. Audi A4 2.5TDI Quattro automatic gearbox help needed
    By Alibi in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2010, 11:38
  3. Automatic Gearbox
    By colinra in forum General Chat
    Last Post: 24th December 2008, 20:28
  4. Automatic gearbox issue
    By pmdk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2008, 15:20
  5. A6 2000 Automatic Gearbox Needed
    By rrippa in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th November 2005, 17:09
