EM TuningSky Insurance
Page 2 of 2 FirstFirst 12
Results 41 to 58 of 58
Like Tree2Likes
Thread: A4 MODS VIA VCDS?
  1. #41
    Rodders.'s Avatar
    Oct 2013
    94
    Tilt not working, but Audi Parking system graphic display is, even without module 76.
    Perhaps the tilt will work later, as the graphic display didn't work and now it does.
    Audi A4 Avant 2.0TFSI 2009 S-Line
  3. #42
    Point_Audi's Avatar
    Vorsprung durch Technik
    May 2010
    Ireland
    433
    Good to hear thr parking graphic is displayed, its cool! I just accessed it a different way!.. Just checking did it confirm the coding was accepted?.. If so make sure the mirror adjusting swtich is switched to the passenger side mirror and engage reverse to see!
    A4 B8 2.0TDI S-Line Executive
  4. #43
    Rodders.'s Avatar
    Oct 2013
    94
    Ahh. I wss going to try putting it on pass mirror position
  5. #44
    Rodders.'s Avatar
    Oct 2013
    94
    Yea the graphi is great. Just need front sensors too!
  6. #45
    Point_Audi's Avatar
    May 2010
    Ireland
    433
    Did that work ok for ya mate?.. Yea front sensor's would be good also, but i would want folding mirrors before!lol
  7. #46
    Rodders.'s Avatar
    Oct 2013
    94
    Yup that works. Really useful as i was a bit dubious having it drop when ever going into reverse. Is there a way to adjust the drop amount? It could do with going a little lower i feel
  8. #47
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    703
    Visit SI-W85's Instagram Channel
    Ok so I've just received my vag com cable and I've had a quick play I've done needle sweep, mirror tilt, seatbelt chime, but couldn't figure out how to get the parking graphic or remove handbrake without seatbelt as it asks me for a code??? Also don't know why but the low fuel warning has disappeared :/ anybody know why this would be???
  9. #48
    Rodders.'s Avatar
    Oct 2013
    94
    Go to the complete list on the other forum and it gives you the code. The vcds software also gives it if you hover the mouse over the box.
    As for fuel. Dunno. You been clicking where you shouldnt? Or had it gone before you started playing?
  10. #49
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    703
    Ok my low fuel light has come back on lol, is it possible to have the lights turn as you turn? Also what do I do when it says enter code presented by program??? How do I do the parking graphic display? Sorry for all the questions
  11. #50
    Rodders.'s Avatar
    Oct 2013
    94
    Do you have a module 76 to access? Theres two ways of doing it.
    Just type the code in the box? Then continue.
  12. #51
    Rodders.'s Avatar
    Oct 2013
    94
    To display the parking graphic (outline of car and sensors/distance to object):
    [10] Park/Steer Assist
    16 Security access -> 71679
    Do It
    07 - Coding
    Byte 0
    bit 4 0->1
    SI-W85 likes this.
  13. #52
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    703
    Not sure it's gone away for the night will look tomorrow. Cheers
  14. #53
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    703
    Sorry I'm new to this vag com stuff it only came today, is that 71679 a code I type in the. Press do it? Then do I change bit 4 from 0 to 1? Cheers
  15. #54
    Rodders.'s Avatar
    Oct 2013
    94
    Follow it. It will make sense. Theres for example 8bytes in a coding page and under each byte there are a number of bits. 0 is off and 1 is on.
  16. #55
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    703
    Good stuff will try it tomorrow thank you
  17. #56
    Jul 2013
    What cable are you guys using for changing these codes? Is it only possible with Ross-Tech cables, or can the cheaper alternatives be used?
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    703
    Quote Originally Posted by Rodders. View Post
    ive done it thanks for your help just struggling to get the hidden mmi menu up and was wanting to try out the flashing lights on heavy braking just to see what they were like but I'm happy with what I've done so far...
  19. #58
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    703
    Anybody know how to get the RS or the S on the mmi screen ???
  1. Cam Timing BKD - What can I do via VCDS?
    By granty578 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2013, 18:01
  2. LED DRL changes via VCDS
    By danb986 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th May 2013, 07:50
  3. S3 09 Faceift with LED DRL's switched on in the off position via VCDS?
    By ApolloS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th April 2013, 14:08
  4. timing via vcds
    By fitzdog88 in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th April 2012, 16:04
  5. Symphony II+ Bose equalizer settings via VCDS
    By Jameze in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2011, 13:50
