Volks AutosSky Insurance
    Jamie-S's Avatar
    Jun 2013
    Coventry
    239
    Audi Drive Select (ADS) 1BL Ride Height
    Can anyone confirm the ride height for a A4 with ADS?
    Apparently its the same as the sport suspension which is 20mm lower than standard suspension, is this true?
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Not speaking from experience but my understanding is that the standard 'sport' springs as fitted to the S Line models and ADS suspension both sit 20m lower than SE suspension. Only the optional S Line springs give you -30mm...
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    Jamie-S's Avatar
    Jun 2013
    Coventry
    239
    Quote Originally Posted by dubdemand View Post
    Yeah that's what I've read but nothing concrete, I will ask at Audi if I go there.
    Reason I want to know is, if I buy a set of springs (eibach pro kit) that lower the standard suspension by 35mm, if you have ADS like me and 'if' it's true ADS models are 20mm lower than standard already your paying £200+- for a 15mm drop.
    I've noticed eibach do a Sportline kit which give a bigger drop but I can't find any anywhere that fit the 3.0 TDi Quattro.....
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    I can completely relate to your post... I toyed with the idea of springs but as we already have the S Line springs (-30mm) it works out to be a lot of money for negligible difference.
    keep us posted as to what you find out
    Jamie-S's Avatar
    Jun 2013
    Coventry
    239
    Asked around about the drop...
    Basically all drop figures are given from standard suspension
    So a 30mm aftermarlet spring kit would make no difference on s line suspension, a 10mm difference on sport (+audi drive select) and ovbiously 30mm on standard.
    Hope that clears it up
  1. Audi Drive Select Effectiveness
    By Zig in forum New A3/S3 (8V Chassis)
    Last Post: 17th January 2014, 19:25
  2. Audi Drive Select help please
    By golfather1 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 6th August 2012, 14:24
  3. Replies: 0
    Last Post: 11th August 2011, 18:19
  4. Audi Drive Select
    By diesebora in forum The Welcome Section
    Last Post: 17th October 2007, 19:33
  5. Audi Drive Select
    By diesebora in forum A5/S5/RS5 Forum
    Last Post: 17th October 2007, 04:51
