Badger5AH Fabrications
Results 1 to 10 of 10
    Aug 2013
    21
    Remove stone chips and haze on plastic headlights - 2.0 TDi S Line 2010
    What would you guys recommend on removing minor stone chips and a slight haze on the plastic head light covers?
    May 2009
    south yorkshire
    628
    remove lights ,sand down preferably with a d/a sander flat off with 2000 grit wet and dry then buff with an electric buffer. come up like brand new .
    Aug 2013
    21
    Quote Originally Posted by hollow View Post
    Thanks. I would rather not remove the headlights. I have found a couple of kits from 3M and Meguairs, I think I may give them a go.
    May 2009
    south yorkshire
    628
    I would really advise you to remove the headlights ,there a 4 torx screws to each light ,2 at the bottom only need to be loosened ,the lights only take a few minutes each side to remove . if you have to sand the headlights and catch the bumper in the process it will be more difficult and time consuming to polish the scratches out of the bumper than it is to remove the lights.
    Nov 2010
    348
    ^ x2
    Dead easy to remove the headlights.
    Rodders.'s Avatar
    Oct 2013
    158
    Might have to do this. Tried to just hand polish yesterday, but they didnt come out much better.
    Nov 2013
    6
    Don't the headlights have a UV coating on them that would be removed if you rub them down ?
    I'm sure i read it somewhere.
    May 2009
    south yorkshire
    628
    yep they do but its obvious that its not doing the job ,thats why the lights after a few year are yellowing off . simple solution is to give them a quick polish every few months by hand with a bit of ultrafine compound and a microfibre.
    or you could recoat them with a uv protectant
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    882
    Visit SI-W85's Instagram Channel
    what can you use for a uv protector as I would like to do this myself?
    Aug 2013
    21
    Thanks for all the info so far guys. Still need to get round to doing this. Will remove headlights and do it when I have time on a sunny day.
  1. Cover for Battery and Control Unit compartment for 2.0 TDi S-Line
    By coldkiwi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd February 2012, 07:15
  2. Bird ****-e removal/stone chips
    By vw754 in forum Detailing
    Last Post: 17th December 2010, 23:05
  3. removing some stone chips and UDM first use
    By abdus in forum Detailing
    Last Post: 26th February 2008, 21:16
  4. Bugs, Stone chips and Stripping!!
    By terrymcg in forum Detailing
    Last Post: 11th September 2007, 14:55
  5. respray - will it remove stone chips
    By tj1978 in forum Detailing
    Last Post: 25th March 2007, 12:49
