Monster MotorsportEM Tuning
Results 1 to 15 of 15
    Dec 2008
    North Yorkshire (Gods Country)
    26
    Add Jenno on Facebook
    Drivers Door Creaking Noise. (Aaaarrrgh!)
    Having just been without an Audi fore a couple of years, i'm back. And so far, not too impressed.
    The main issue is a constant creaking/rattling noise from the rear of the drivers door.
    Its somewhere between shoulder and ear height and its driving me to despair.
    So far ive tried the following:-
    Removing the door trim and tightening the torx screws inside.
    Covering the rubber door seals and plastic window surround in silicon.
    Driving with the window down.
    All to no avail.
    If you slightly open the door while driving the noise goes away.
    Has anybody else had this issue and for the sake of my sanity, how did you cure it ?
    Jenno
    Oct 2013
    Canberra, Australia
    Jenno - try some white lithium grease on the door catch itself...my Tiguan did the same and drove me nuts for a while until I applied the grease and haven't heard anything since. I have an Oz S4 Avant and that was one of the first things I checked but its pretty new anyway but I was concious of it - all the best from downunder
    27,087
    Welcome to the site David.
    Also striker plate may need slightly adjusting.
    Nov 2005
    UK
    586
    I had a similar thing and it turned out to be the small screw which holds a white plastic part ( I think part of the locking mechanism ) which sits behind the door skin...took the door trim off and the screw was loose so I replaced it with a slightly larger one and that cured it......really screwed up the door from taking it off though, so anyone doing this, be carefull with the plastic lugs which hold the door card on !!!!!
    Trouble is, I can hear all the other rattles now !!!
    Apr 2012
    26
    As NHN said, I recently moved the striker plate in by around 2mm and cured 80% of the problem. Haven't had time to try whether another mm or two will solve the rest. By the way, a normal torx will fit the bolts just about well enough to do the job :-/
    27,087
    My advice is use the correct spline tool, as torx can damage the socket & thus cause you loads of grief, should you need to remove/adjust later on
    Apr 2012
    26
    Where can you buy the correct tool? Must admit it felt wrong with the torx.
    27,087
    Halfords do a very good 7 piece socket set for approx. £25, never failed me & had no cause to buy anyother sizes thus far.
    Apr 2012
    26
    As easy as that! Must have missed that. I'll grab one before I try that again.
    For anyone else, here's a link:
    http://www.halfords.com/webapp/wcs/s...5215&langId=-1
    2,159
    If your taking the door car off buy replacement plastic clips part number (8E0 868 243) and are around 30p each they always break, and even more so in cold weather.
    riggssuzuki's Avatar
    Jan 2012
    Elgin, Scotland
    444
    MIne creaked and groaned until i had the door seals lubed. Just a thin smear of silicon type grease on the rubers and noise gone.
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    May 2009
    south yorkshire
    628
    now the cold weather is here ,the seat belt rubs against the leather seat and squeaks like hell .
    Apr 2012
    26
    I think I've identified the source of the rest of my creaking noise. It's the cloth-covered bit of trim covering the seat belt slider on the B pillar. It creaks when I go over bigger bumps. What I haven't been able to do is to cure it!
    It comes off very easily by peeling the door seal out of the way and pulling the piece of trim inwards. I gave it some silicone grease on the mountings, but it still isn't silent. Any ideas?
    Apr 2012
    26
    As an update, I actually replaced the above-mentioned bit of trim some time ago, and the creak's still there. So back to square one!
    SI-W85's Avatar
    Sep 2013
    Huddersfield uk
    881
    Visit SI-W85's Instagram Channel
    Somebody else started a thread regarding the bit of trim you are talking about I'm sure they cured it so I would have a look for that...
    Custom stainless straight through quad pipe, S5 brake callipers, Black diamond grooved discs, red stuff pads, S4 diffuser, EGR delete, stage 1 remap, 19" staggered X5 wheels, G23 custom adaptors, stretched tyres, window tints, coilovers, vag com mods, K&N, led interior lights, led number plate bulbs, pressed plates, black edition grill. Plenty more to be done.
  1. Replies: 8
    Last Post: 12th December 2012, 09:52
  2. drivers window/door 'creak'
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th October 2007, 13:21
  3. Drivers Door Problems
    By deano16v in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th February 2005, 19:31
  4. A6 Rear Driver Door Problems
    By daver in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st December 2004, 21:13
  5. Bizarre door creak...
    By PreacherCain in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2003, 15:57
