JMB RetrofitsAH Fabrications
    Jan 2011
    119
    A4 B8 2.0 TDI 143 2008 front wheel Bearing replacement HELP!
    Hi all,
    I have recently found the wheel bearing on front passenger side is failing and I will need to get it replaced! I wondered could anybody give me any advice on how to remove and refit and what tools needed, sockets and bits etc.? Also were would be the best place to purchase a new bearing.
    Any help would be much appreciated.
    Chris
    Nov 2010
    346
    The bearing comes complete with a flange that fits onto the hub carrier and a new allen screw that goes in the end of the driveshaft. £109 from Audi main dealer.
    Its just nuts and bolts to fit, but you might need a slide hammer to get it apart.
    You might as well do both sides, mine went within 2 months of each other!
    B6Rich's Avatar
    Dec 2006
    Mine went after about 120k and having just changed my front discs and pads myself, and having had issues with seized disc location screws etc and both sides taking me a total of 8 hrs (to save £100)... I took mine in to my local VAG specialist. Good job too, He had the tools and Oxy-Acetalene which he needed as it was seized solid and took 2.5 hours aledgedly. Just under £200 inc parts per one side!
  1. front wheel bearing 2.0 tdi part number??
    By kaos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2011, 23:53
  2. Anyone had a new front wheel bearing fitted on their A3?
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2010, 18:38
  3. Front Wheel Bearing/Hub Assembly
    By gavinsky23 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th February 2010, 18:40
  4. DIY S3 Front wheel bearing....
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2009, 21:32
  5. Front Passeneger wheel bearing replacement - Any tips or guides
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2005, 18:48
