Monster MotorsportBadger5
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,971
    is tension on this cambelt ok(VIDEO)
    2.0 TDI CR.....JUST DONE CAMBELT,IS THIS OK...........MOV_0942_zps9b76c637.mp4 Video by vw754 | Photobucket
    ITS NOT DEAD TIGHT BUT ITS NOT LOOSE EITHER,IM SURE THERE NO SUPPOSED TO BE DEAD TIGHT ANYWAY..........TENSIONER IS SET TO WHAT IT SHOULD BE,BUT APPARANTLEY THE SPROCKETS CAN BE UNDONE TO GET THAT LITTLE MORE TENSION AT THE TOP,BUT IM SURE IF I DO THAT IT WILL BE VERY TIGHT....IT WAS BAD ENOUGH PUTTING THE BELT ON,AS IT WAS VERY TIGHT.
    Full leather/19"wheels/cruise/
    May 2009
    south yorkshire
    628
    when i fitted my cam belt i actually moved the pointer round further than the mark on the tensioner as the belt did fell a little loose.
    too tight and it will damage the tensioner
    Nov 2010
    346
    That roller looks a bit dodgy with the black stuff partially stuck on it....
    vw754's Avatar
    Nov 2006
    U.K
    1,971
    Quote Originally Posted by Zafi View Post
    quite normal after fitting some belts apparantley,nothing to worry about,had it checked out all is ok....nothing dodgy lol....everything is genuine parts.
  1. Toothed Belt in Service Book/Is this Cambelt?
    By jaydav2306 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2012, 16:24
  2. Checking ABF semi-automatic cambelt tensioner
    By HTC in forum Volkswagen and other VAG
    Last Post: 12th November 2004, 06:21
  3. check this video out.. it is excellent
    By chuckys3 in forum General Chat
    Last Post: 19th August 2004, 23:33
  4. Cambelt Tensioner - Know Issue???
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2004, 07:56
  5. Hello, my 1st post -You may want to see this video
    By dakiller in forum General Chat
    Last Post: 17th July 2003, 11:14
