JMB RetrofitsChris Nott
    Nov 2012
    S Wales
    11
    Central Locking fault
    Hi, I have been having problems with my central locking system for the past couple of weeks. The drivers door is not opening when all the other doors are fine. I have to lock the car and open again only that this is getting progressively worse, in that last night I had to repeat this five times before the drivers door would open. This morning it worked first time? I have tried the spare fob and there is no difference to what is happening. I hope this is not going to be an expensive electrical fault so if anyone has any information on rectifying my problem I will gladly take it.
    May 2009
    south yorkshire
    628
    not had to deal with one of the b8 locks but if it works on the same principal as the b7 , then it will be one of the 2 micro switches in the door lock.
    not a cheap part . but cant be cheaply fixed is you have any technical skills .
    Nov 2012
    S Wales
    11
    Thanks hollow, do you have any more details for me to go on? I thought I might get a bit more information from the forum but sounds like it's not that common a fault. I am not really good at taking door cards apart so might get some quotes this week.
    May 2009
    south yorkshire
    628
    tis a bit more involved than just taking the door card off , the lock mechanism has to come out , and one of the micro switches has to be replaced , the part is roughly £3 from somewhere like maplin or rs components . but will require a bit of skill to make it fit .
    Feb 2012
    Camberley Surrey
    Have the same problem with my 2007 A3 1.9tdi, been going on for about a year just the driver,s door wont open and as you say it has been getting worse so you are not alone with this fault,
    Dexy.
  1. Central Locking Fault Code: 01030
    By Blacky165 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd July 2012, 17:27
  2. 2000i A3 1.6 Sport - Central Locking Pump / Electric Windows fault
    By msowerby in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2011, 20:28
  3. Central locking fault when wet
    By barters3 in forum TT/TT-S/TT-RS Forum
    Last Post: 1st September 2010, 21:06
  4. central locking fault!
    By G4GAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2009, 17:59
  5. Fault code on Audi S3 Central locking
    By jesters3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd September 2007, 20:37
