AH FabricationsVolks Autos
Like Tree3Likes
  • 3 Post By dieseldoos
Thread: A4 B8 rear brake pads, how too?
    tedward's Avatar
    Aug 2012
    Lancashire
    168
    The rear pads need doing on my 58 plate A4 but the pesky electric handbrake is making it look nigh on impossible for a d.i.y,er .
    Can anyone recommend a link to a how too without using the plug in caliper re-set gizmo or am i going to have to stump up at a garage?
    There is a gunsons re set tool on e bay which might be worth a go?
    Gunson Electronic Park Brake Reset Tool | eBay
    thanks.
    2009 A4 B8 2.0 TDI SE + 2006 A3 1.9 TDI SPORT SPORTBACK
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Look for someone near you with a VCDS. As far as I'm aware this is the only way of retracting the caliper to allow for a pad change unfortunately...
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    26,716
    You not considered buying vcds for both your cars, then its money gone towards a single tool to do many jobs
    dieseldoos's Avatar
    Apr 2013
    Hampshire
    110
    You can do it without VCDS allthough its better if you have it.
    If your confident you can use use a 12v car battery to retract the pistons.
    The electromechanical parking brake is a 12-volt motor that engages and retracts the rear brakes.
    To retract the rear wheel parking brake, you will need access to a 12-volt battery and two jumper wires. One of the jumper wires should have an insulated clip on the end so you do not short-circuit the wires.
    When you are looking at the caliper you will see the brake line and electric wire/connector going to the rear caliper.
    Disconnect the electric connector from the caliper. Inside the connector on the caliper side you will see two medal pins sticking up. Connect the two jumper wires to the 12 volt battery.
    Take the negative wire jumper and connect it to one of the pins on the caliper. Then take the positive wire and touch the other pin without touching the other jumper wire and causing a short.
    If the caliper piston starts to push out, stop!, reverse the jumper wires. You should hear the parking brake retract and the piston not move.
    Continue until the caliper piston starts to spin, stop! Now push the caliper piston back in with a brake tool, c-clamp, etc. Replace pads as you would normally. After all the brakes have been replaced. Pump brake pedal until you have a firm pedal. Check the brake fluid. Then turn on and off the electromechanical parking brake a few times and you should be good to go. Very simple!
    tedward, DrSasso and JG51 AUD like this.
    2009 ​Audi A4 2.0TDI S-Line (143)
    Fully registered VCDS in Portsmouth & surrounding areas , and fault scanning of other makes.
    tedward's Avatar
    Aug 2012
    Lancashire
    168
    Now that's what I'm talking about, there's always a way! Spare battery in the garage and plenty of wire about, pads ordered.....sorted.
    Some local jockey wanted to charge me £50 to connect the laptop to rewind the pistons and £47 to fit the pads?..no thanks.
    Quote Originally Posted by dieseldoos View Post
  1. Rear brake pads
    By SDO in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd August 2008, 22:40
  2. Rear Brake Pads & Caliper Tool ???
    By roy_barber99 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th July 2008, 21:35
  3. Rear Brake Pads - which brand
    By g60leigh in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2008, 09:14
  4. Rear brake pad change...
    By oversteer in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2007, 14:21
  5. Changing rear brake pads (A4 Avant)
    By NickB in forum General Technical / How To
    Last Post: 4th November 2006, 16:38
