Volks AutosMonster Motorsport
Results 1 to 9 of 9
    Apr 2012
    49
    MMI Dead! Help please!
    Hi All,
    Was driving car yesterday and MMI screen froze up, screen went blank but radio stayed on (even when removing key and locking doors)! Had to remove 7.5 amp fuse to turn radio off! Have now re-fitted 7.5amp fuse but all is dead. No screen display and no lighting on switches around gear shifter. I have checked all fuses located in Left & Right dash and Boot and they are all fine. I am also able to eject & load CD's in head unit.
    Car is 2009 B8 MMI 2.
    Anyones help would be gratefully appreciated
    Jan 2012
    1,599
    Get it scanned for faults as a priority - then clear and rescan.
    Apr 2012
    49
    Ok will do. Thanks
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,926
    when my other halfs went dead i left the fuse out for 24 hours on been to to do so by audi sheffield
    and its been fine sinse
    i did scan and no faults were there.
    Jan 2012
    1,599
    Or disconnect the battery for 30 mins and try again.
    Apr 2012
    49
    Hi Chris,
    Was it the 7.5amp fuse you removed?
    26,723
    Do an mmi reset now fuse has been refitted & if no go, battery of for 2 minutes & back on, start car then test.
    Apr 2012
    49
    Just performed an MMI reset (setup, dial button & top right button) - No joy.
    Also removed Batt lead for 5 mins - Still no luck!
    Apr 2012
    49
    So took the car into Audi today and they have come back saying theres a fault with J523 Display Unit! They need to investigate further! Anyone had or know about this please?
  1. 2005 Audi A6 MMI is dead. Help is needed to identify the fault
    By SuperPuper2000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th February 2014, 22:44
  2. Help please - OBD port dead!!
    By mk2vr6 in forum Volkswagen and other VAG
    Last Post: 5th December 2012, 21:21
  3. Serious problem S3 is dead need help please!!
    By s3cya in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2012, 20:09
  4. S3 is DEAD! Help Required ASAP Please
    By Ryan_W in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2011, 00:28
  5. Ipod connection for MMI Navi Plus?!?!? HELP PLEASE PEOPLE
    By fatboytex in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2009, 18:04
