JMB RetrofitsAH Fabrications
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By johnnevett
Thread: Hill hold assist
    Jul 2013
    140
    Hill hold assist
    Hi all
    is hill hold assist a retrofit option for the b8?
    Is it just a case of installing the right switch and programming?
    Is there any guides anywhere to help do this ?
    cheers
    john
    27,096
    Requires abs module to be compatible.
    Jul 2013
    140
    Thanks for the reply
    how do I check if the module is compatible
    cheers
    27,096
    With vcds, check if its got the option.
    Jul 2013
    140
    Ok, thanks.
    if the option is there is it just the switch that would be needed?
    Jun 2013
    14
    Is this just the auto hand brake release when you pull away?
    i just thought it was a standard feature?
    Feb 2013
    Hampshire
    62
    Found this interesting link on the subject: AudiEnthusiasts Hill Hold Assist Install
    Jul 2013
    140
    Quote Originally Posted by Leeroy1 View Post
    No, it's a different switch which makes the car hold when stationary once engaged you don't have to keep pressing it like the normal hand brake switch
    Audi Dynamik likes this.
    Feb 2008
    Quote Originally Posted by johnnevett View Post
    Ok, thanks.
    You also need to run wiring from the ABS module in engine bay to the new switch in the centre console.
    Jul 2013
    140
    Quote Originally Posted by Spr0cket View Post
    Even if the option is already there in vcds like mentioned above?
    Is there a guide to this wiring if not
    cheers
    Apr 2009
    Coventry
    2,219
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
  1. Hill Hold Assist VCDS Mod
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th April 2014, 11:35
  2. Hill Assist / Hill Hold Assist
    By hittchy in forum New A3/S3 (8V Chassis)
    Last Post: 20th June 2013, 09:22
  3. Hill Hold Assist enabling with VCDS
    By digon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th December 2012, 18:45
  4. Hill Hold
    By nicks3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2005, 21:24
  5. Hill Hold
    Last Post: 10th June 2005, 16:06
