Badger5Sky Insurance
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By gary3306
Thread: Rear Disks and Pads
    AshA4's Avatar
    Ash
    Sep 2004
    Newport, South Wales
    193
    Question Rear Disks and Pads
    I will need new rear disks and pads soon and a mechanic that does all my fathers work will do them for a damn site cheaper than Audi (with trade parts as well) so am getting the front pads done at the same time.
    I have heard a rumor that you need VCDS to retract the caliper piston, is this true and if so is there a way around this?
    B8 A4 Avant 2.0 TDi 143 | S-Line Executive | Lava Grey | Privacy Glass - Auto Dim/Fold Mirrors
    Soft lad's Avatar
    May 2010
    137
    Quote Originally Posted by AshA4 View Post
    Sadly yes, you need to electrically wind then back. Audi make more money then.
    27,099
    Oh come on now, that's a ridiculous statement to make, its got nothing to do with VAG making more money, the systems weren't designed for vag to coin it, they were designed with number of things in mind, ergonomics, cabin space & allow better designed console/interior.
    AshA4's Avatar
    Ash
    Sep 2004
    193
    So do I have to get the done at Audi?
    Or will an Indi have the tools?
    dieseldoos's Avatar
    Apr 2013
    Hampshire
    137
    If your confident you can use use a 12v car battery to retract the pistons. (If you have not got access to Vagcom or an Electric brake service tool).
    A good indie can do this, or...
    The electromechanical parking brake is a 12-volt motor that engages and retracts the rear brakes. To retract the rear wheel parking brake, you will need access to a 12-volt battery and two jumper wires. One of the jumper wires should have an insulated clip on the end so you do not short-circuit the wires. When you are looking at the caliper you will see the brake line and electric wire/connector going to the rear caliper. Disconnect the electric connector from the caliper. Inside the connector on the caliper side you will see two medal pins sticking up. Connect the two jumper wires to the 12 volt battery. Take the negative wire jumper and connect it to one of the pins on the caliper. Then take the positive wire and touch the other pin without touching the other jumper wire and causing a short. If the caliper piston starts to push out, stop!, reverse the jumper wires. You should hear the parking brake retract and the piston not move. Continue until the caliper piston starts to spin, stop! Now push the caliper piston back in with a brake tool, c-clamp, etc. Replace pads as you would normally. After all the brakes have been replaced. Pump brake pedal until you have a firm pedal. Check the brake fluid. Then turn on and off the electromechanical parking brake a few times and you should be good to go. Very simple!
    2009 ​Audi A4 2.0TDI S-Line (143)
    Fully registered VCDS in Portsmouth & surrounding areas , and fault scanning of other makes.
    Soft lad's Avatar
    May 2010
    137
    Not sure if you're taking the P or not
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    He isn't lol
    NHN likes this.
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
  1. Need new rear disks and pads for 2.0T
    By whitelightning in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th April 2012, 21:26
  2. Disk and Pad fitting - how to?
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2009, 13:33
  3. Rear discs and pads
    By Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2006, 14:32
  4. Rear Discs and Pads
    By in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2005, 18:49
  5. rear discs and pads, help please.
    By S3tony in forum Handling
    Last Post: 8th February 2005, 10:48
