AH FabricationsBadger5
Results 1 to 9 of 9
    Jul 2013
    39
    Couple of annoying little problems
    Hi our 61 plate a4 2.0 tdi teknik has a couple of annoying problems the first is everytime we start it the climate control turns itself right up to 12 not sure if this can be set different and also the stop start rarely works I've been told it doesn't always work but it probably only works 1 out of 100 times just wondered if this can be reset or if there's a problem with it thanks
    dieseldoos's Avatar
    Apr 2013
    Hampshire
    137
    The stop/start will only work if it meets all the requirements (engine warm etc). I normally turn mine off as soon as I start the car!
    What setting is the climate control on? Mine is set to Auto, and all I ever do is adjust the temprature (I leave the air con on).
    2009 ​Audi A4 2.0TDI S-Line (143)
    Fully registered VCDS in Portsmouth & surrounding areas , and fault scanning of other makes.
    May 2012
    Bucks
    66
    The stop start won't work if you have the climate turned right down as it will need the engine to keep running for the aircon to keep trying to cool the car down! Why do you want it down below 12?
    61 Plate Audi A4 Saloon Black Edition 2.0 TDI 170 in Lava Grey
    Audi Dynamik's Avatar
    Sep 2011
    2,113
    12 ? Are we talking about the fan here ?
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    27,014
    Yes my 1st question as above is, is it set to auto on climate, if so, disable this & manually turn it down, see if it goes back to auto on startup again & 12 fan speed.
    Is the temp set to a low or particularly high which warrants the 12 speed when in auto mode, if so adjust this & fan speed usually drops accordingly & as above it may affect the start stop aswell if you adjust these systems.
    You need to provide more info on your setup & have a play to see if it makes any differences.
    Jul 2013
    39
    Hi thanks for your replies yes it's set to auto and usually set to low with air con on and every time we start the car it goes right up to fan speed 12 which is a bit noisy I will have a play around with it this afternoon and see how it goes thanks
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    If you have the temp set to 'Lo' then it will always blow on maximum as it's basically just cooling as much as it physically can rather than attempting to reach a certain temperature. Your best bet is to set it to a comfy temperature like 19 degrees or something and it will regulate the fan speed instead of just blasting you.
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Jul 2013
    39
    Hi I've upped the temperature a bit and all seems to work fine now thanks for your help
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Glad to hear it!
  1. New week new annoying little problem!
    By coopsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2010, 22:06
  2. hi guys, a little problem
    By S3ren in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2008, 19:13
  3. Little problem with FMIC
    By Rev-head in forum Tuning
    Last Post: 7th January 2007, 22:45
  4. Very annoying boost problem!
    By W8 Performance in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2006, 23:37
  5. New User, New Car, Little Problem.
    By Rainesie in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2004, 01:26
