AH FabricationsChris Nott
Results 1 to 18 of 18
    Nov 2008
    178
    Coilovers queries
    Hi have anyone fitted coilovers to there b8 model and which one they use .. And where and how much .. Not looking too spend too much . Let me know and how is the ride quality as well .. Thanks
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    Did you have a budget in mind?
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Hi, I fitted AP coilovers for about £480 delivered if I remember rightly... Had them on since October and haven't had any issues with them at all. Ride quality is better than the standard suspension (I have S-Line suspension). Notice them most when you chuck the car into a corner to be honest.
    As for fitting, I got a VW tech to fit them so can't really help with details I'm afraid. Took about an hour and a half was all, and that was him figuring out the suspension setup first because he'd never worked on one before.
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Nov 2008
    178
    @Dmp not too expensive but at the same time something that wouldn't fail me within a 2yrs period . I had air ride on my b7 model and in the process of selling those . Ones they are sold I will eventually go back on air ride . For the me time I just wanted some coilovers to carry me through for a year time till and I mount the air ride system on ...
    Nov 2008
    178
    Dag thanks for the info .. Do u know by chance if the rears on the b8 is the same as b7 or not .. Because I know the front is the same only difference the struts are different at the bottom .
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    I couldn't tell you I'm afraid, I've not seen a B7 setup. I'd assume it would be very similar but can't give you a definite answer I'm afraid...
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    As mentioned above the AP kit is a good option.
    Give me a shout if I can be any help with prices.
    DPM Performance
    T: 01207 561606
    Nov 2008
    178
    @ DMP what the best price you can do me on them Ap kit .. I don't want to spend too much .
    Nov 2008
    178
    Dag where did u get them from what is the website . Thanks
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    It's been a while but I think it was from Venom Motorsport?
    Nov 2008
    178
    Ok.. But how much it is there as I phone the, and they saying £509 ... Anyway cheaper.. I have been doing some research and some folks saying ap coilovers don't go as low as the fk ones is that true or not .. And the rear adjuster is sort of a problem to adjust and don't go low enough... Seeing that you has fit them you might know more ..
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    Quote Originally Posted by jaceyq View Post
    £510.00 delivered.
    DPM Performance
    T: 01207 561606
    Nov 2008
    178
    Is that the cheapest you could do .. Any offers..
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Maybe it was £480 plus delivery then? Been a long time since I ordered them! Haha.
    The rear on mine is as low as it will go and the adjusters have been taken out too. The rear wheel is just very slightly up in the arch, maybe 5mm or so?
    The front you could drop stupidly low if you wanted, there is as much adjustment as you could want. So unless you're wanting the wheels tucked right into the arches then the kit should be fine?
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Here's a pic of it next to a B7 RS4 so you can see the difference. The rear is about the same height as the front, so hopefully you'll be able to tell if it would be low enough for you!
    Nov 2008
    178
    Ok . Am considering .. How is the drive dag . Soft , any noises in front ...
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    The drive is really good. Better than with the standard S-Line springs.
    I get a slight noise near lock at slow speed and a scrub when I have a little steering on and hit a bit of a bump but I think that's just becuase the front is as low as it is. I've been meaning to raise it up 5mm or so for a while... Lol. Nothing that really affects driving at all though. Wouldn't put me off...
    Nov 2008
    178
    That's what I was thinking , because previous ride I lower and got that as well from the down force on the tracking rods ball joints. And because of it low as well and the pressure on the steering rack you will get that scrubs when turning at lower speed rather than high speed ...
  1. V-Maxx coilovers fitment query....
    By SMc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2011, 16:27
  2. H&R Coilovers... Please help for the S3
    By s8n in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 06:28
  3. Suspension Query..
    By Lowride in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2003, 01:31
  4. Coilovers vs dampers & springds
    By dbm in forum Handling
    Last Post: 4th September 2003, 07:36
  5. Quick question about Audi a4 coilover kit
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2003, 22:13
