EM TuningMonster Motorsport
Results 1 to 9 of 9
    Jan 2013
    10
    DPF removal recommendations - London/Surrey
    Hi All,
    I have 2008 2.0 TDI Avant (143) and got the dreaded DPF light come up and again, first time since January but and I’m bored of worrying about it and trying to force a regen. I would really like to have it removed and remapped.
    I know there are lots of threads relating to DPF’s but I was wondering if anyone could recommend a decent place in Surrey, South West or South East London to do the necessary work.
    All help and advice greatly appreciated especially what it is likely to cost.
    27,028
    Could ask Simon@amdtechnik in Woking, top bloke.
    Jan 2013
    10
    Thanks for the reply i have sent AMD a message, I was hoping to find someone who could gut the current DPF and remap the sensors out, and any suggestions/recomendation of anyone that has done this.
    Nov 2010
    332
    My engine management light came on, then the DPF light, but it was a sensor problem that only cost £85 including fitting.
    Jan 2013
    10
    Hi Zafi, Thanks for the info, i'm think mine could be a sensor as i had the DPF warning on Friday, tried re-gen it a number of times, then no faults on Monday and yesterday i got the DPF, glow plug light flashing and the engine management light on again. I guess i need it scanned to see if it is the sensors?
    May 2009
    south yorkshire
    628
    there is no need to map the sensors out or remove the dpf for that matter . a little trick which will save you money both in a remap and a dpf removal .
    it does involve some work but is cheaper and cleaner than a full dpf removal and works 100% of the time
    locate the dpf on the exhaust and either remove it or do it in situ . we do them in situ as we have a ramp .
    quickest way is drill straight through the exhaust next to where the exhaust exit pipe from the dpf is at an angle and then through the dpf catalyst . do not drill through the cat which is located in the same piece .
    you can tell when you have drilled through the dpf as there is a space between the dpf and the cat . use at least a 12mm drill bit and drill 2 holes close to each other . fill the holes in the steel exhaust with weld . (20 mins work altogether)
    or remove the exhaust from the rear of the dpf and same idea but using alot longer drill bit (sds drill bits are great for this)
    once drilled use vcds to program the vehicle as you have fitted a new dpf .
    benefits + very little exhaust smoke ,remap is fine and not effected ,cheaper remap without dpf delete , no paying £100 + for a full dpf removal from vehicle .
    Nov 2010
    332
    Quote Originally Posted by bhav187 View Post
    Yes, get it scanned. When I Googled the fault code it was very common. So common that when I phoned the independent VAG workshop and asked them for a price to change my exhaust pressure sensor the person on the desk gave me a price straight away! Must be an everyday job for them.
    Jan 2013
    10
    Thanks for the information, getting a mate to scan the fault codes for next week when he is back from holiday.
    I think the drilling the dpf is a bit beyond my capabilities.
    Jun 2011
    135
    try these guys in rainham FR&RTuning: Wez-Nik Autoservices Rainham
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
  1. A6 2.0 TDIe remap and DPF removal recommendations in the South
    By SuperPuper2000 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 13th January 2013, 22:00
  2. Where to get my DPF removed and remapped in London
    By santosc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th October 2012, 22:46
  3. DPF removal on Audi A4 (B7) 2.0 Tdi 170 Quattro Avant
    By Holywood in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd July 2010, 19:14
  4. Specialist near Croydon/S. London/Surrey?
    By Matt T in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2008, 21:44
  5. Any tuned S3 owners in South London/Surrey?
    By costa_k in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 21:11
