Sky InsuranceVolks Autos
    M7R
    Type Approval Engineer,
    Sep 2008
    Chilwell, Notts
    212
    EGR issues - check yours mines clogging up after 15k!
    I have a 2012 seat exeo fitted with the 170bhp common rail engine like the b8, and I have been getting rubbish mpg, one guy on seat-cupra.net has has his cut out, and the dealer said there is a know issue with 140s and the egr/ throttle, and he has had the same on his 170..
    Theres far more b8s than exeos so I wondered if you guys had any problems, or could check your egr valves, this is mine,
    Can other folks check theirs, ESP 170 owners and post up how their looks after x many miles, it's dead easy to do, the enine cover just lifts off, and then it's a flat head screwdriver to undo the the jubilee clip, then just pull the pipe off, a 2 min job,
    Karl
    83 GTi - road legal track weapon - now running 2.0l 16v super charged, = FAST!
    Daily hack: Audi A4 Avant S Line 2.0TDI Motech map to 175bhp, Milltek twin exit system, 1/2 leather, DIS, Fan washer jets, B8 rear aero wiper, FK headlight,
    Nov 2010
    218
    My DPF light came on the other day, so I did a motorway run at 4000 rpm for 15 miles, seems to have cured it.
    Sep 2013
    24
    EGRs clogs up usually when the DPF is full . It forces exhaust gases through the EGR.
  1. Check your drain holes, people
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th June 2012, 20:25
  2. Audi A6 C5 - check your plenum chamber - mine was full of water
    By Alski2009 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd January 2011, 00:34
  3. always check your childs homework
    By voorhees in forum Jokes, Games & Humour
    Last Post: 5th May 2009, 18:14
  4. check your aerial... look at what happened to mine.
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2007, 18:15
  5. Check your wheels
    By imported_Macduff in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2006, 05:16
