Volks AutosJMB Retrofits
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By Tay
  • 1 Post By GeoffDunk
Thread: Dimming DRLs when Indicating
    Tay
    May 2012
    Warrington
    370
    Hi All,
    I'm looking for a bit of assistance with the coding to make the DRLs dim when indicating on a 2008 S Line. I'm going to have a go at sorting this tomorrow for my mate and all I can find info on is the "wink" feature which appears to turns the DRL off completely when indicating.
    I'm guessing if this can be done, can the brightness of the DRLs be controlled so they dim by say 50%?
    Any help with this would be very appreciated!
    jamin128 likes this.
    riggssuzuki's Avatar
    Jan 2012
    Elgin, Scotland
    445
    Mine is set like that as standard. They dim when the indicator is on.
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    Jun 2011
    Wellingborough
    1,174
    as said, they shouldnt turn off when indicating, they should dim.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    golfather1's Avatar
    Sep 2008
    80
    I done mine with VCD now they don't dim when indicate & yes you can increase the brightness
    Tay
    May 2012
    Warrington
    370
    Could somebody possible send me there standard long coding for central electrics module? Need to try and get to the bottom of this, the car does not has LED wink active but they turn off when indicating :s
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Add GeoffDunk on Facebook
    Quote Originally Posted by golfather1 View Post
    Do they go off at all if they dont dim? If not this could prove do be dangerous as the bright LED mask the orange of the indicator. This is the purpose of them dimming.
    New MOT rules will cover this at some point.
    ScottishS3 likes this.
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    Mar 2014
    Poole
    86
    Anyone now where to enable dimming and increase brightness on VCDS?
    Mar 2010
    19
    Hi Guys,
    Apologies for hijacking the thread, but seems appropriate to post here
    I have a 2010 A6 S-Line Quattro with the adaptive Xenon's and LED DRL strip within the headlights. They do not dim or switch off on indicate (Factory standard on the Le Mans?)
    I have VCDS (newbie user so be gentle!)
    Could someone give me a line by line step on how to code to force the DRL's to dim on indicate?
    Should add that Ive not been able to find a "wink" option within the hidden MMI 3G menu structure...
    Much appreciated.
    John.
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    650
    I hope the following helps, these are for B8 platform cars, but will probably work for the C6 A6 platform too - worth a try.
    Disable LED 'wink' on turn signal
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
    Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code shown by VCDS)
    [Adaptation - 10] -> Channel 3
    Set between 5 and 100
    Not my info, shamelessly stolen from this thread.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    Mar 2010
    19
    Thanks Benjie, will give that a go tomorrow.
    John.
    benjie's Avatar
    Oct 2009
    650
    Happy to help, any luck?
  1. DRL LED Lights Dimming with using indicators
    By pherbert in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th April 2012, 14:52
  2. Problem when indicating!!
    By Sm3g in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th October 2009, 19:10
  3. Service when indicated or by mileage
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2008, 16:57
  4. Beeping when indicating!?!?!?
    By G Force in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th October 2006, 15:58
  5. Dim Display when hot
    By robert97r in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th September 2006, 15:06
