Badger5Chris Nott
    Mar 2013
    7
    Clutch judder/drivetrain wobble
    Car is in the dealer for the above problem as well as steering noises. Just had a call from the garage to say they have changed the rubber hose on the power steering which should fix everything. Now I am not an expert bit I fail to see how replacing a power steering hose can fix clutch noise an gearbox "wobble" (for want o a better description. Any body got any comment or useful references that I can use when I pick the car up tomorrow!??
    Apr 2009
    Coventry
    2,219
    Take the tech out with you when you pick it up and see if its still wobbling.
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Mar 2013
    7
    Will do. Annoying thing is its one of those elusive intermittent faults....he may have a nice scenic drive tomorrow morning!
    Apr 2009
    Coventry
    2,219
    sods law.my dual mass has been playing up for two years and when under warranty never played up when i took it to the dealer
    Pass me my sock
    Mar 2013
    7
    Update. They have replaced hydraulic tube for PS which seems to have cured the steering noises and poor feel that we had experienced. Technician wants the vehicle back to drop the gear box out to investigate further......
  1. Clutch judder from cold in damp weather
    By Macduff in forum Diesel forum
    Last Post: 1st March 2007, 09:47
  2. clutch judder
    By petespug in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2006, 18:05
  3. Clutch Judder
    By jerryhigby in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th January 2005, 11:14
  4. Clutch judder, only done 25k
    By jbreedon in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd August 2004, 20:09
  5. Clutch judder, only done 25k
    By jbreedon in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th July 2004, 03:03
