Volks AutosSky Insurance
Thread: Gearbox whine
    Mar 2013
    7
    Gearbox whine
    Morning
    We have an A4 avant B8 2.0 TDI it's 2009 model year.
    It is currently in the workshop at the dealers as there are a few niggles with it although its got 12mnths approved used scheme warranty.
    One of the issues is a transmission whine, the technician said that this was normal for this model.
    Can anyone confirm this or otherwise??
    It seems really difficult to get into 1st and 2nd, likewise the technician suggested this is normal too......any body with similar experience??
    Mar 2013
    17
    Not sure that it helps, but my 2010 2.0TDi quattro gearbox whines a bit, but then so did my 55 B7 A4 TDi from new to 170K.
    Yep, 1st and 2nd gears are quite notchy, especially when cold.
    Mine had a new clutch and flywheel (thankfully under warranty), and whilst sorting the clutch judder when hot, it makes no difference
    to the 1st and 2nd gear selection.
    Mar 2013
    7
    Thanks stubill.
    It's in having some drive train "wobble" under load checked out - possible that this is something to do with the DMF too I guess. We also get a little clutch judder when cold.....wonder if they will offer a replacement....
  1. Audi S3 2007 8P1 Gearbox Whine
    By delta7 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2013, 03:45
  2. A3 3.2 manual Gearbox whine
    By cj.dub in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2012, 21:06
  3. Gearbox whine and oil level
    By Raveydavey in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2010, 17:26
  4. A4 2.0tfsi poss gearbox whine?
    By mo_mo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th January 2010, 21:06
  5. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
