A/C doesn't work! Had gas checked and it is OK, so ran a VCDS scan and got the below. Had a similar issue in June 2011, fixed under warranty - I don't know the details (didn't run a scan that time) but they said it was a wire that needed replacing (took 2-3 days to order it in).
Car went in for service and first MoT in January while still in warranty (just), they didn't pick up on the fault codes (which are dated Dec 2012) as Audi say they don't routinely run a fault code diagnostic when doing a service / health check!?!? Which is annoying as we took it back to Audi while in warranty in case anything like this was found!
Faults indicate a communication error between the main switch panel (J255) and the central electronics module (J519), A/C Pressure/Temperature Sensor (G395) and Air Quality Sensor (G238). Then errors between the central electronics module (J519) and the A/C Pressure/Temperature Sensor (G395) and Air Quality Sensor (G238).
Anyone had a similar issue, know where these sensors are or how I could check them? Is it easy to take the main switch panel out and check for a loose wire behind? Would the J519 communicate with G395 and G238 via J255 (in which case it could be a dodgy bus connection on J255?
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0171
Revision: D0000000 Serial number: 01111120090412
Coding: 66140000
Shop #: WSC 06335 000 00000
VCID: 76E7BE01C1C445A80B0
3 Faults Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Date: 2012.11.22
Time: 15:46:18
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Date: 2012.11.22
Time: 15:46:18
Freeze Frame:
Temperature: 12.0°C
01592 - Air Quality Sensor (G238)
004 - No Signal/Communication
Date: 2012.11.22
Time: 15:46:20
Freeze Frame:
Temperature: 12.0°C
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H25 0380
Revision: 09025001 Serial number: 00000000507984
Coding: 260050914034AF010001000000001D0D0F1D470A00010141000000
VCID: 3A7F6A31B55CE1C82F8
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 061109 H05 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
2 Faults Found:
Date: 2012.11.22
Time: 15:46:00
Date: 2012.11.22
Time: 15:46:00
Coding: 66140000
3 Faults Found:
Date: 2012.11.22
Time: 15:46:18
Date: 2012.11.22
Time: 15:46:18
Freeze Frame:
Temperature: 12.0°C
Date: 2012.11.22
Time: 15:46:20
Freeze Frame:
Temperature: 12.0°C
Coding: 00FD11
Coding: 025028
2 Faults Found:
Date: 2012.11.22
Time: 15:46:00
Date: 2012.11.22
Time: 15:46:00
