Hi all, first post here so trying to make myself useful, rather than just a bid for someone else to help. There's quite a bit of info online about this, (location etc) but a few details missing so I'll share how far I've got.
Background:
A/C didn't work and when I did my yearly service, so plugged in my VAG scanner and was surprised to find quite a few codes...
08 Auto HVAC 00256 A/C pressure Temperature Sensor (G395) Sporadic 008 - Implausible signal
00457 Control Module for network (J519) Sporadic 013 - Check DTC Memory
01592 Air quality sensor (G238) - sporadic 004 No signal/connection
09 Cent Elec 03020 local data bus 2 - sporadic 012 - electrical fault circuit
and some other most likely unrelated door issues.
And whilst searching for answers came across an Audi technical bulletin that sums up our problems (do a google search for 2020124-2, the pdf file titled
Air conditioning inoperative was a massive help.
So i inspected the sensor and did not see any corrosion.
Today I took it for a A/C service and recharge at a Halfords Autocenter for £49, and left the panel that covers the sensor off so they could see if it leaked as expected in the Audi technical bulletin (although because of the good condition of the sensor I didn't expect it to leak)...
It leaked
It was hissing from the G395 pressure sensor and so they drained the gas.
They drained the system and now it's back on the drive again. So I've taken it apart to see if it's corroded inside making the most of knowing there's no pressure in it. It's these pictures I hope are useful for others as I've not seen them anywhere else.
These pictures show the valve that sits under the sensor, so it should be safe to change under pressure. It also tries to show the oily residue from where it leaked inside the connector. It appears to have crept around and past some of the pins.
The bumper did not need to be removed. Just required a 17mm spanner. less than 10min job to replace.
So I'm weighing up my options: -
Replace myself (Part from Ebay £30 from china (by part number listed in the technical bulletin mentioned in this post), and then another £49 for halfords to recharge the system. (but maybe it or something else will leak?) all in £79 if all goes well.
Or Audi £61 for the sensor + £3 for new 0-ring. Audi also quoted me £80 for labour ontop of that, and then £79 ontop of that again for the aircon recharge. (get a 2 year warranty on it though) £223 all in, if all goes well.
Halfords will get back to me on monday with their price.
Thats my experience with the problem so far, hope it helps someone. Likewise if anyone has any advice for me or can shed some experience it would be appreciated.
Cheers, Dan
