Monster MotorsportVolks Autos
    Mar 2011
    32
    B8 S4 Oil consumption
    I have been reading so much about the oil consumption. Mine is running buring very little compare to most people, several thousands miles for half a litre if not less. Should I be worry that the MMI not reading correctly or I should call myself lucky!?!?
    Nov 2005
    UK
    584
    Mine didn't use much...it depends how it's been run in, but don't trust the MMI as mine had a mind of its own.
    You can buy a dipstick from ECS (I think) which is a straight replacement for the plastic plug which comes as standard and means you can check your oil the old fashioned way !
    Feb 2008
    107
    Dipstick via local dealer, think mine was 8 quid.
    s4tronic's Avatar
    Jan 2013
    Edinburgh
    23
    How easy it is to fit dip stick? Any guide available?
    riggssuzuki's Avatar
    Jan 2012
    Elgin, Scotland
    439
    As easy as remove the black plastic cap and stick in the dipstick in its place.
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
  1. A4 Cab 2.4V6 - Is my oil consumption normal?
    By imported_lewiscsfb in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd May 2005, 11:24
  2. PD130 Oil Consumption?
    By imported_Macduff in forum Diesel forum
    Last Post: 20th October 2004, 22:51
  3. Newbie... question about A3 oil consumption
    By imported_wallj in forum The Welcome Section
    Last Post: 16th July 2004, 08:23
  4. X-post for a friend: A3 Oil consumption too high
    By ImolaS4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 13:13
  5. A4 TDI 130 Oil Consumption
    By neiltdi in forum Diesel forum
    Last Post: 16th December 2003, 09:25
