Badger5Sky Insurance
Results 1 to 7 of 7
    Jan 2012
    1,837
    A4 B8 Concert III AMI CODING
    Anyone have the above?
    AMI installed, picking up iPod, showing Audi logo and accessory connected but we can't find the relevant coding in the long coding helper.
    The headunit has the MEDIA button fitted.
    Part number of radio is shown below.
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
    Component: Concert3 H06 0350
    Revision: 00000010 Serial number: AUZ5Z6K1577795
    Coding: 0702008201028D00035B070000
    Shop #: WSC 06335 123 12345
    VCID: 458529DACC61CA3052A
    Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
    Component: Display
    No fault code found.
    Jan 2012
    1,837
    Anyone? Someone must've retrofitted this!
    Mar 2013
    I can't help you Chris but I'm as keen as you to find out as this is something I plan to do. Did you install it yourself and did you buy the parts from Audi.
    Jan 2012
    1,837
    Hi Bustanut,
    We finally got the AMI going -
    Enable Media Player 3 in the CAN Gateway, then go into Module 56 (Radio) and go to Byte 11 within the long coding helper .. In that byte there will be a bit which is called Multi Device Interface (MDI) settings active. Tick this, close VCDS and lock the doors using the key.
    Wait a few minutes, turn the car on and now select AMI from the source menu in the Radio.
    Parts were from Audi but I'm not sure how much they were as the unit was installed beforehand.
    What threw me off was, that I was looking for Audi Music Interface, not Multi Device Interface so once that was ticked, the whole system worked.
    Mar 2013
    Chris, thanks for the reply. Glad to hear you got it working. I am trying to decide if it's worth the expense at the moment as I can still load 6 CDs and have an sd card full of music. Audi dont make these things simple or cheap do they.
    mike60eley's Avatar
    Jan 2007
    Telford
    260
    Quote Originally Posted by Bustanut View Post
    If you don't mind me butting in, i've got the AMI system in my car and we use to change from my wifes iphone to my galaxy s3 to get the music. But we always use sd card or the changer now, it might be me but sd system sounds a lot clearer.
    [IMG][/IMG][IMG][/IMG]2010 Audi A4 2.0 TDI S line Exec, Misano Red, AMI, Phone & Voice Prep Bluetooth, CD Changer, DAB, 19" Alloys, Black Pack, Alcantara Heated Seats, Cruise Control, Start Stop, White LED Mod, Tints.
    Jan 2012
    1,837
    Definitely not cheap nor simple (well simple when you have your head screwed on which I clearly didn't! ) but well worth it.
    Mike, the quality of the track itself has a lot to do with the output but I find listening to a track (the same one) thru SD or AMI it sounds exactly the same.
  1. Anyone on here have the AMI with the Concert III?
    By Dazza0685 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 13th February 2012, 11:26
  2. Chorus CD v Concert III
    By dkjc in forum In-Car Entertainment
    Last Post: 24th April 2007, 18:36
  3. Concert III
    By matthewnics in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2007, 09:17
  4. New Concert III
    By giblets46 in forum In-Car Entertainment
    Last Post: 3rd January 2007, 13:26
